02-06-2017 12:24 AM - edited 03-17-2019 09:26 AM
Hi Team,
would like to know what Disconnect cause code =41 means . attached is the debug output.
Solved! Go to Solution.
02-06-2017 01:06 AM
Below link contains all disconnected cause codes, chick the table search for cause code41.
It will help
http://www.cisco.com/cisco/web/docs/iam/unified/ipt611/Using_Call_Flows_to_Resolve_Call_Processing_Problems.html
02-06-2017 01:06 AM
It will help
02-06-2017 01:10 AM
Hi, it says "network failure". that means network failure from SP end or our internal network ?
02-06-2017 01:52 AM
Hi, it means whatever network media between "connecting" your device with the SP (ISDN, Fiberoptic, ethernet cable .. etc) it failed and need to be provisioned from the administrator of that network. it could also be being failed from your side.
Your side represented in the port that connecting your device to the SP.
Hope that help
02-06-2017 02:03 AM
thank you .
02-06-2017 02:15 AM
You Wellcome, if that all for ya, please press "correct answer" to close the threat and to help others searching for the same issue.
