Disconnect cause code =41
SwathyEdayath
Hi Team,
would like to know what Disconnect cause code =41 means . attached is the debug output.
saif musa
Level 4
Level 4
Below link contains all disconnected cause codes, chick the table search for cause code41.
It will help
http://www.cisco.com/cisco/web/docs/iam/unified/ipt611/Using_Call_Flows_to_Resolve_Call_Processing_Problems.html
5 Replies 5
saif musa
Level 4
Level 4
It will help
Hi, it says "network failure". that means network failure from SP end or our internal network ?
Hi, it means whatever network media between "connecting" your device with the SP (ISDN, Fiberoptic, ethernet cable .. etc) it failed and need to be provisioned from the administrator of that network. it could also be being failed from your side.
Your side represented in the port that connecting your device to the SP.
Hope that help
thank you .
You Wellcome, if that all for ya, please press "correct answer" to close the threat and to help others searching for the same issue.
