Disconnect Cause SIP 480 Outbound Calls through E1 PRI
Ing.Alejandra
Hello All,
I'm getting erro : SIP 480 , when I try to call to PSTN  through E1 PRI connection. Any suggestions? the carrier says : I'm OK  , they tested directly in their equipment and the call was ok.
Pls help ! :(
Logs look :
The Call Setup Information is:
Call Control Block (CCB) : 0x0x22A55F68
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 462
Called Number : 9995797269
Source IP Address (Sig ): 172.16.214.1
Destn SIP Req Addr:Port : 172.16.214.17:5060
Destn SIP Resp Addr:Port : 172.16.214.17:5060
Destination Name : 172.16.214.17
.Oct 18 18:21:18.968: //12405/70AA6476A024/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : g711alaw
Negotiated Codec Bytes : 160
Nego. Codec payload : 8 (tx), 8 (rx)
Negotiated Dtmf-relay : 6
Dtmf-relay Payload : 101 (tx), 101 (rx)
Source IP Address (Media): 172.16.214.1
Source IP Port (Media): 17298
Destn IP Address (Media): 172.16.214.17
Destn IP Port (Media): 31686
Orig Destn IP Address:Port (Media): [ - ]:0
.Oct 18 18:21:18.972: //12405/70AA6476A024/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 18
Disconnect Cause (SIP) : 480
My configuration is :
dial-peer voice 50 pots
description locales chile
destination-pattern 9[2-9][1-9].......
port 0/0/0:15
forward-digits 9
dial-peer voice 70 pots
description a celulares_CHILE
destination-pattern 99[5-9].......
port 0/0/0:15
forward-digits 9
dial-peer voice 40 pots
description Llamadas a Internacional
destination-pattern 9T
port 0/0/0:15
L# sho controllers e1
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info FPGA Rev: 08121917, FPGA Type: PRK1
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
International Bit: 1, National Bits: 11111
Data in current interval (79 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
3978 Line Code Violations, 8 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
1 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 843 Unavail Secs
#show voice port
ISDN 0/0/0:15 Slot is 0, Subslot is 0, Sub-unit is 0, Port is 15
Type of VoicePort is ISDN-VOICE
Operation State is DORMANT
Administrative State is UP
No Interface Down Failure
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 0 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is A-law
Region Tone is set for US
Station name None, Station number None
Translation profile (Incoming):
Translation profile (Outgoing):
Voice class called number pool:
lpcor (Incoming):
lpcor (Outgoing):
DS0 channel specific status info:
IN OUT
PORT CH SIG-TYPE OPER STATUS STATUS TIP RING
0/0/0:15 01 isdn-voice dorm none none
0/0/0:15 02 isdn-voice dorm none none
0/0/0:15 03 isdn-voice dorm none none
0/0/0:15 04 isdn-voice dorm none none
0/0/0:15 05 isdn-voice dorm none none
0/0/0:15 06 isdn-voice dorm none none
0/0/0:15 07 isdn-voice dorm none none
0/0/0:15 08 isdn-voice dorm none none
0/0/0:15 09 isdn-voice dorm none none
0/0/0:15 10 isdn-voice dorm none none
0/0/0:15 11 isdn-voice dorm none none
0/0/0:15 12 isdn-voice dorm none none
0/0/0:15 13 isdn-voice dorm none none
0/0/0:15 14 isdn-voice dorm none none
0/0/0:15 15 isdn-voice dorm none none
0/0/0:15 17 isdn-voice dorm none none
0/0/0:15 18 isdn-voice dorm none none
0/0/0:15 19 isdn-voice dorm none none
0/0/0:15 20 isdn-voice dorm none none
0/0/0:15 21 isdn-voice dorm none none
0/0/0:15 22 isdn-voice dorm none none
0/0/0:15 23 isdn-voice dorm none none
0/0/0:15 24 isdn-voice dorm none none
0/0/0:15 25 isdn-voice dorm none none
0/0/0:15 26 isdn-voice dorm none none
0/0/0:15 27 isdn-voice dorm none none
0/0/0:15 28 isdn-voice dorm none none
0/0/0:15 29 isdn-voice dorm none none
0/0/0:15 30 isdn-voice dorm none none
0/0/0:15 31 isdn-voice dorm none none
Aseem Anand
Can you make a test call and collect the following:
1. Debug ccsip messages
2. debug voice ccapi inout
3. Debug isdn q931
4. Sh run
Aseem
Hi Aseem.
Here you are...
calling Party Number  320
called number : 9227857889
thanks a lot!
I don't see problems in the call flow. Your router sent a SETUP message but the end user didn't answer the call hence the call was terminated.
.Oct 19 23:42:42.328: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8163
	Cause i = 0x8092 - No user responding
Above debug shows that cause code 18 was the termination cause which is user not responding. The gateway mapped this to SIP 480 message.
Summary no problems from your end just make sure that end user answers the call.
