That version of CM requires the 7.0(1a) version of DMA, it's available on the download pages.
Alternately you could download the 7.0(2) version of CCM, and apply that upgrade as part of the server build process when prompted whether you want to install a patch; you should then be able to import your current DMA export.
7.0(1) is already 2 years old.. should you not be aiming for a newer release?
Aaron
Please rate helpful posts...
Aaron
Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
