04-02-2009 01:32 AM - edited 03-15-2019 05:14 PM
The Installation of the DMA Tool abort while installing the IDS, but i dont know why.
I think this is the interesting part in the Log File:
The full Log File is attached.
19:05:34: MSIUtils.cpp: fnSetRegValue: fnDeleteRegValue; Function started
19:05:34: MSIUtils.cpp: fnSetRegValue: fnDeleteRegValue: Registry value \HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Tcp1323Opts not found.
19:05:34: MSIUtils.cpp: fnSetRegValue: fnDeleteRegValue: Function ended
19:05:34: DMAInstall.cpp: fnIDSInstallPostCheck: Registry key Tcp1323Opts was not added by IDS installation
19:05:34: DMAInstall.cpp: fnUpdateOnconfigCCM: --> fnUpdateOnconfigCCM
19:05:34: DMAInstall.cpp: fnDmaDeleteFile: --> fnDmaDeleteFile
19:05:34: DMAInstall.cpp: fnDmaDeleteFile: File=C:\INFORMIX\etc\ONCONFIG.ccm
19:05:34: DMAInstall.cpp: fnDmaDeleteFile: Unable to change attribute to normal for C:\INFORMIX\etc\ONCONFIG.ccm
19:05:34: DMAInstall.cpp: fnDmaDeleteFile: Error in removing C:\INFORMIX\etc\ONCONFIG.ccm: 2.
19:05:34: DMAInstall.cpp: fnDmaDeleteFile: File not found in the directory.
19:05:34: DMAInstall.cpp: fnDmaDeleteFile: <-- fnDmaDeleteFile
19:05:34: DMAInstall.cpp: fnUpdateOnconfigCCM: Error: fnDmaDeleteFile(ONCONFIG.ccm) returned 2
19:05:34: DMAInstall.cpp: fnUpdateOnconfigCCM: <-- fnUpdateOnconfigCCM
19:05:34: DMAInstall.cpp: fnIDSInstallPostCheck: Error: fnDeleteRegValue(Tcp1323Opts) returned 2
19:05:34: DMAInstall.cpp: fnIDSInstallPostCheck: <-- fnIDSInstallPostCheck
Action ended 19:05:34: InstallFinalize. Return value 3.
Action 19:05:34: Rollback. Rolling back action:
04-06-2009 11:33 PM
Problem solved by SR
07-21-2009 03:07 AM
Do you have the ticket number.? I am running into the exactly same problem and i have open a SR but maybe they could find the solution faster if i could refer to a case where it has been fixed.
