DN preference on CUCM
tato386
Level 6
Level 6
In CME I can create multiple DNs for the same extension number and use different sequence numbers and preferences to setup something similar to a sequential hunt group with out needing several different extension numbers. Is there something similar in CUCM?
Diego
Jaime Valencia
No, in CUCM you can only add URIs, alternate numbers and E.164 numbers, but they all point to the same DN, just different options to dial.
java
if this helps, please rate
So by the same token I guess that means that I cannot add the same DN to multiple buttons on one phone?
