06-08-2015 08:16 AM - edited 03-17-2019 03:15 AM
How can I switch on-off the DND function in my phone? reading user guide, there are just few lines "Turn DND On and Off
Procedure
Step 1 Press DND to turn on DND.
Visual confirmation displays briefly.
Step 2 Press DND again to turn off DND.
Visual confirmation displays briefly"
Well, where DND key or soft key??????
Best regards
Claudio
06-08-2015 08:31 AM
Have you configured DND to be in your softkey template???
If not, that's why it's not showing, configure it and it'll show.
06-08-2015 08:36 AM
06-08-2015 08:38 AM
You configure that in CUCM or CME, if you're an end user get in touch with your local IT support team for this.
06-08-2015 08:41 AM
Thanks. But my feeling is that I has been able to "enable" DND function doing some wrong operations on the phone. I already call my IT center... but I'm still waiting. For your understaning there is no possibility to operate just on the phone?
06-08-2015 08:55 AM
Just curious, did you press the more button on the Softkey? It may be scrolled back (Redial, New Call, CFWD All , More)
06-08-2015 08:56 AM
yes... the others softkeys are pickup gpickup callback mobility hlog...
06-08-2015 12:19 PM
But is there DND softkey as well? If not then it probably needs to be configured.. just wondering how did you manage to get into the DND state to begin with?
06-09-2015 12:41 AM
No, there is no DND softkey; the phone went in DND state after some attempts that I did in order to store some number in the personal director... but if and what can be the relation?
Regards and tks
