IP Telephony License renewal
peternnaji
I need an urgent help,
I have a client that wants to renew their UC licenses to the latest version available.
I have attached the licenses.
Please kindly advice on how to go about the upgrade/renewal.
Prompt responses will be highly appreciated.
Peter.
Aaron Harrison
You wouldn't do that by posting the client's licenses on a public forum.
I'd suggest you send your client to a Cisco Partner for advice. There are a lot of questions to be answered that I suspect you don't know how to ask...
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron is correct[+5]
From the attachment,I can see you have got UCSS which is used for major upgrades.You can initiate mail to ucss-support@external.cisco.com to get detailed info on how to activate the PAK codes  and place the order through PUT [Product Upgrade Tool] to have licenses along with Application S/w for latest versions.
regds,
aman
