05-03-2019 06:17 AM
I have 3 generic SIP phone devices (actually 3 x SPA303 Cisco Small Business phones) registered to CUCM 11. They use a 3rd party SIP device types as they are not recognised as anything within the Cisco phone portfolio.
I am trying to get a single DN to appear on line 1 of each device. A Shared Line. When trying to add the DN to the second device, CUCM provides an error "Update failed. Shared Line feature is not supported"
Is this a limitation of 3rd party SIP devices? (the phones themselves support unto 3 lines) or some other config I have missed? Shared lines work OK on standard 88xx series enterprise phones.
05-03-2019 08:37 AM
I'm running CUCM 11.5.1.13902-2 and was able to do what you described without issue using either the SIP Basic or SIP Advanced phone type.
05-03-2019 02:56 PM
The quick solution is to create a huntgroup that is broadcast, 3 different DN's added to it.
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
