Do-not-disturb Softkey
snooter
CUCM 6.1(1a)
I've got a handful of 7940/7960 phones that I put the DND (do-not-disturb) softkey on. Works good. However, for some reason when the user hits the DND button on the phone to enable it, the phone displays the word "UNDEFINED!" on the screen.
DND works just fine when it's enabled, so I'm not sure what this "UNDEFINED!" is. Did I maybe missing something when configuring the custom softkey templete? Or is that word something I can configure in an xml maybe? It's almost like it's looking for a label for the softkey I've pushed, but it's not....well...defined. Where might I "DEFINE" it at?
6 Replies 6
paolo bevilacqua
Which phone Fw do you have ? Can you try latest that is 8.0(7) ?
Got the latest sccp, 8.0(7)
I can't suggest a reason beside "sw anomaly".
E-BRITTON
did you ever find a solution to this? have you tried the latest sw 8.0.8? Have a customer getting the same error
thanks
We are using CUCM Version 6.1.1.3101-1 and experience this error on our CP-7940 Phones with 8.0(9) Firmware and german locale.
The newer CP-7940G Phones work correctly (same Firmware).
Is this Problem fixed in 6.1.2?
Fixed.
Upgrading to 6.1.2.1000-13 did not help, but after we made a Factory-Reset the Phones displayed the correct information.
Maybe a Factory-Reset helps with older Callmanagerversions too.
