Does CME support SIP INFO method for DTMF
Anukalp S
Hi.. i have come to know that CME does not support SIP INFO DTMF method. It supports only Notify and RTP-nte with SCCP phones.
CME currently supports this DTMF internetworking for SIP to SCCP calls:
*    SCCP out-of-band-SIP Notify / RFC2833 since 12.4(4)T"
Can you pls confirm on this.
Nadeem Ahmed
Currently CME supports this list of DTMF internetworking for SIP to SIP calls:
*         Notify <---> Notify since 12.4(4)T
*         RFC2833 <---> Notify since 12.4(4)T
*         Notify <---> RFC2833 since 12.4(4)T
*         Inband G711 <---> since 12.4(11)T [Requires Transcoder]
CME currently supports this list of DTMF internetworking for SIP to SIP calls:
There is DDTS enhancement opened for the same
https://tools.cisco.com/bugsearch/bug/CSCse50733/?reffering_site=dumpcr
Br,
Nadeem
Br, Nadeem Please rate all useful post.
Nadeem Ahmed
Br,
Nadeem
Vivek Batra
The SIP INFO Method for DTMF Tone Generation feature is always enabled, and is invoked when a SIP INFO message is received with DTMF relay content. This feature is related to the SIP NOTIFY-Basec Out-of-Band DTMF Relay Support feature, which provides the ability for an application to be notified about DTMF events using SIP NOTIFY messages. Together, the two features provide a mechanism to both send and receive DTMF digits along the signaling path.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/sip/configuration/12-4t/Configuring_SIP_DTMF_Features.html#GUID-066261A3-5065-4787-A25B-37553A4A9BA9
I've never faced a situation to use SIP INFO with any of the service provider since RFC2833 is most reliable for that purpose.
