Downgrading Unity Express from 3.0.1 to 2.3.2
pepito1983
Hi, i have a problem downgrading Unity Express from 3.0.1 to 2.3.2 Actually the customer has an Unified Communicator version 4.3(1)sr1 and following the compatibility matrix i will need CUE version 2.3.2 but i receive a NM-CUE with CUE 3.0.1 and it is not compatibility.
Well i think it will be easy to make a downgrade to CUE 2.3.2 , i have downloaded all the archives that i started the boot helper program successfully but when i want to load the package cue-vm.2.3.2.pkg it appears the following error:
Please select from the following
1 Install software
2 Reload module
3 Disk cleanup
(Type '?' at any time for help)
Choice: 1
Package name: cue-vm.2.3.2.pkg
Server url: ftp://192.168.1.64/
Username: anonymous
Password:
Downloading cue-vm.2.3.2.pkg
Bytes downloaded : 137065
Validating package signature ... error
Package signature validation failed for pkg cue-vm.2.3.2.pkg
Unable to install. Please try again
1 Install software
2 Reload module
3 Disk cleanup
Please i need a hand with this, only just in case i am using Vista as a FTP server, just in case.
Thanks in advanced ...
Jose
2 Accepted Solutions
craiglcve
Level 4
Level 4
could you try running the install software clean command?
software install clean url ftp://X.X.X.X/cue31/cue-vm-k9.nm-aim.X.pkg
The X's are the ip address and the cue pkg name.
Hope that helps.
Craig
I don't think that's available. It's basically a clean install. If possible, I'd use the online installer (software install clean...) method. If not, then try using the 3.0 installer image (from the TFTP server). I know it seems backwards, but the problem is that the 2.3 installer probably can't handle the post-3.0 upgraded system.
7 Replies 7
craiglcve
Level 4
Level 4
Hope that helps.
Craig
craiglcve
Level 4
Level 4
Also there is a command from the CUE CLI
software install downgrade
But I think this only works if you have had a previous image installed before an upgrade to 3.x but you might want to try that as well.
Craig
Hi Craig, i was looking for the CUE 3.0 release notes and there is no information about if i cab make a downgrade from 3.0.1 to 2.3.2
Do you have information about this, thanks in advanced.
Jose
Yeah! it works with the online clean installer command. Thanks for all your help ...
Jose
Glad to hear it.
