Download issue with UCSInstall_UCOS_UNRST_7.1.5.33900-10.sgn.iso
iptuser55
Level 6
Level 6
I`m trying to down load the latest SU due to the above "UCSInstall_UCOS_UNRST_7.1.5.33900-10.sgn.iso" but when I try to download it it closes almost straight away - has anyone downloaded it recently
thanks
Rob Huffman
Hi IPT,
I just tried a test download and it seemed OK I only let it go
for about 2 minutes but it was chugging away before I cancelled it.
I did notice that when I first clicked "proceed with Download" that it tried to
open it with "Nero" rather than save to xxxx which is the standard for most
downloads.
Cheers!
Rob
Hi Rob
When ever I try to download it the file size is always 1k
Another question we are upgrading form 7.1.2b to 7.1.5x - Do I upgrade first to 7.1.5 then install the SU4 or can I can install the SU4 straight away - I thought the SU4 was more of a ES so it is installed after the base build so to speak of 7.1.5
thanks
Someone else is downloading for me - so all good. Strange though I down loaded the 7.1.52b version ok but failed with the above version
