DPC3008 only using one DS channel (Amber light)
Joe Swenson
After upgrading to the DPC3008, I have only 1 downstream channel and 1 upstream channel.
 I know there is one solution on the Comcast forums. However, there is only one Engineer there that knows how to escalate this issue to to get the problem resolved. And it is not his job to do so. He claims "UPDATE:: We have found the issue and are working to correct it via firmware update.  That update will not come for some time.  But we have a way to correct it for issue modems right now.." Dated 10-14-2013.
Any help with DCP3008 Only bonding on one channel (Amber DS light) issue would be highly appreciated.
As of today no firmware updates have been posted here: http://support.linksys.com/en-us/support/gateways/DPC3008
About
Model:
Cisco DPC3008
Vendor:
Cisco
Hardware Revision:
1.0
MAC Address:
bc:c8:xx:xx:xx:xx
Bootloader Revision:
2.3.1_R3
Current Software Revision:
d3000-v302r125532-121212a-L2VPN-CMCST
Firmware Name:
d3000-v302r125532-121212a-L2VPN-CMCST.bin
Firmware Build Time:
Dec 12 19:27:51 2012
Cable Modem Status:
Operational
Wireless Network:
Cable Modem State
DOCSIS Downstream Scanning:
Completed
DOCSIS Ranging:
Completed
DOCSIS DHCP:
Completed
DOCSIS TFTP:
Completed
DOCSIS Data Reg Complete:
Completed
DOCSIS Privacy:
Enabled
Downstream Channels
Power Level:
Signal to Noise Ratio:
Channel 1:
3.8 dBmV
41.7 dB
Channel 2:
0.0 dBmV
0.0 dB
Channel 3:
0.0 dBmV
0.0 dB
Channel 4:
0.0 dBmV
0.0 dB
Channel 5:
0.0 dBmV
0.0 dB
Channel 6:
0.0 dBmV
0.0 dB
Channel 7:
0.0 dBmV
0.0 dB
Channel 8:
0.0 dBmV
0.0 dB
Upstream Channels
Power Level:
Channel 1:
39.0 dBmV
Channel 2:
0.0 dBmV
Channel 3:
0.0 dBmV
Channel 4:
0.0 dBmV
amchang
Hi Joe,
This discussion has been incorrectly posted to the wrong community on the Cisco Support Community. This community is specifically for feedback pertaining to the site.  In future, please select the proper community area when submitting posts. A listing of the most common communities are available at the top in the Community Directory.
Amy Chang
Dan Lukes
Firmware of such kind of product may be customized for particular operator/seller. So only operator may provide updated firmware to you.
See Cisco Consumer Set-Tops, Modems and Gateways
