IP Telephony and Phones
Personalize banner_3
Labels
I am working on a CUCM cluster that was recently upgraded to 9.1.1.20000-5 and since the upgrade the corporate directory on the 7925 phones is not working. The user just gets and error of not found. We have tried performing a factory reset on the 792...
putney_m by Level 4
  • 640 Views
  • 3 replies
CUCM 10.5.2.11900-3, recently upgraded from 6.xxCalling to an outside number from a remote building, caller ID shows the wrong building on some phone carriers, but is correct on AT&T which provides our PRI lines.Example:  Call to my AT&T cell, caller...
Resolved! Outgoing calls
Hi all, I have a customer with different sites, and they requested in case a site goes down, they want all the calls to be routed to a different site, I doubt is, should I add this to the Route list configuration (Route List Member Information) or Ro...
HI all, I have an issue with a customer, when they dial and Outside phone, after a few seconds the call goes directly to a internal ext. I checked the route patterns and are ok, in the voice gateway to the outside dial-peer I added the "huntstop"  bu...
