Showing results forĀ
Search instead forĀ
Did you mean:Ā
DSP Question- do I need them ?
iptuser55
Level 6
Level 6
I have  the following cards in a router to be installed but I need to check the required DSP`s as I need to move some around to another router. I checked with the DSP calculator but need a 2nd opinion
NM HDV2-2T1/E1 x 2 ports
VWIC2 2MFT T1/E1 x 2ports
VWIC3-2MFT T1/E1 x 2ports
total 6x E1
I`m running 3945 on IOS15  , the calculator states I do not require any DSP`s is this correct? It is only a E1 Gateway no resources as such Conf, Transcording etc
many thanks
acampbell
I think I have anwered this on your other similar post.
Alex
Regards, Alex. Please rate useful posts.
https://supportforums.cisco.com/message/3460470#3460470
https://supportforums.cisco.com/message/3460242#3460242
This actually the 3rd time he's asking this same question.
Short answer.
Are they going to be data E1s???? then NO
Are they going to be voice E1s, therefore doing voice termination??? then YES
I have a card on my router and it's going to be doing voice termination, do I need DSPs??? YES
If you're going to do voice and the calculator says you don't need DSPs most likely you're not using it properly or filling in the right info.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
The reason it has appeared 3 times, was when I created this thread  nothing happened when I rechecked-  so thinking I was fat fingers created it again  Dont know if the Board was slow or what but it did not appear until the next day at least
