E1 CAS help, 2 Problems
Marcusdj
HI,
I'm currently having 2 issues with an E1 at let say site A. The first problem is any B end site that is connected to this A end site experiences a ringing on the associated lines.
For example. A end has 4 circuits going to site B, at site B all 4 lines will receive a ringing if they don't have the lines pinned to the speaker. Its like there is ARD but i can confirm that the A ends PABX system is set to MRD
The second problem is that at random times of the morning or evening i see voice-ports drop for afew seconds then come back up.I have no alarms at all when i check on the router . Below is the message i receive on my Syslog.
A End Syslog
09/16 04:56:23.222 10.x.x.x local7.notice 549: *Sep 16 01:48:39.645: %HTSP-5-UPDOWN: Trunk port(channel) [1/1:8(8)] is down
09/16 04:56:30.502 10.x.x.x local7.notice 550: *Sep 16 01:48:46.929: %HTSP-5-UPDOWN: Trunk port(channel) [1/1:8(8)] is up
B end Syslog
09/16 04:56:23.251 10.x.x.x local7.notice 468: *Sep 16 02:38:24.133: %HTSP-5-UPDOWN: Trunk port(channel) [1/0:13(13)] is down
09/16 04:56:30.495 10.x.x.x local7.notice 469: *Sep 16 02:38:31.377: %HTSP-5-UPDOWN: Trunk port(channel) [1/0:13(13)] is up
the  E1 is configured as the following
Site A
controller E1 1/1
Framing crc4
ds0-group 1 timeslots 1 type e&m-immediate-start
ds0-group 2 timeslots 2 type e&m-immediate-start
ds0-group 3 timeslots 3 type e&m-immediate-start
ds0-group 4 timeslots 4 type e&m-immediate-start
ds0-group 5 timeslots 5 type e&m-immediate-start
ds0-group 6 timeslots 6 type e&m-immediate-start
ds0-group 7 timeslots 7 type e&m-immediate-start
ds0-group 8 timeslots 8 type e&m-immediate-start
ds0-group 9 timeslots 9 type e&m-immediate-start
ds0-group 10 timeslots 10 type e&m-immediate-start
ds0-group 11 timeslots 11 type e&m-immediate-start
ds0-group 12 timeslots 12 type e&m-immediate-start
ds0-group 13 timeslots 13 type e&m-immediate-start
ds0-group 14 timeslots 14 type e&m-immediate-start
ds0-group 15 timeslots 15 type e&m-immediate-start
ds0-group 16 timeslots 17 type e&m-immediate-start
ds0-group 17 timeslots 18 type e&m-immediate-start
ds0-group 18 timeslots 19 type e&m-immediate-start
ds0-group 19 timeslots 20 type e&m-immediate-start
ds0-group 20 timeslots 21 type e&m-immediate-start
ds0-group 21 timeslots 22 type e&m-immediate-start
ds0-group 22 timeslots 23 type e&m-immediate-start
ds0-group 23 timeslots 24 type e&m-immediate-start
ds0-group 24 timeslots 25 type e&m-immediate-start
ds0-group 25 timeslots 26 type e&m-immediate-start
ds0-group 26 timeslots 27 type e&m-immediate-start
ds0-group 27 timeslots 28 type e&m-immediate-start
ds0-group 28 timeslots 29 type e&m-immediate-start
ds0-group 29 timeslots 30 type e&m-immediate-start
ds0-group 30 timeslots 31 type e&m-immediate-start
voice-port 1/1:8
define Tx-bits idle 1101
define Tx-bits seize 0101
define Rx-bits idle 1101
define Rx-bits seize 0101
no comfort-noise
timeouts call-disconnect 3
connection trunk 51013
dial-peer voice 42008 pots
destination-pattern 42008
port 1/1:8
dial-peer voice 51000 voip
destination-pattern 510..
voice-class codec 1
session target ipv4:10.x.x.x
0 Replies 0
