E1 migrate from CMM module to New Cisco 3945
Syed Akbar Ali
Dear Support ,
As we migrate the E1 lines from CMM module to new Cisco 3945 router , after then we not able to dial outside through E1 . its give message call can't be complete as dial . same configuration is configured on router as in cmm ,
new 3945 router came by default as mgcp profile default. and it can't be allow to remove also. on router we configure  as h.323 protocol.
so please advice .
your fast response will be highly appreciated.
Thanks in advance for your kind support.
Syed
Jorge Armijo
Level 4
Level 4
The message "The call cannot be completed as dialed" sound like the CUCM anunciator. Can you post the Route Pattern configuration and also the dial-peers on the H323 Gateway? Are you doing digit strip on the CUCM?
Actually if you can post the "show run" from Gateway and some pint screen from CUCM so we can have a better idea how the setup is on both devices.
Jorge Armijo
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
