E1 slip errors causing random static issue
ejlbarcelon
Level 3
Level 3
I have 3 E1 bundled from same service provider and after a few months we had complaints regarding static noise heard over the the other line when we call someone from the office. This is random, at no particular time or day, but not always. When we check the E1 we see slip errors on all three E1 with the same amount of errors each.
I have searched here in the forums for solutions but all were suggesting different things, some say dont put "network-clock-participate" some says you need it. Some say to put the clocking on internal, some says on line (external).
I have 2 wic with 2 ports of E1. Here is my current config:
network-clock-participate wic 0
network-clock-participate wic 1
controller E1 0/0/0
 clock source internal
 pri-group timeslots 1-31
controller E1 0/0/1
controller E1 0/1/0
router#sh network-clocks
  Network Clock Configuration
  Priority      Clock Source    Clock State     Clock Type
    10          Backplane       GOOD            PLL
  Current Primary Clock Source
router#sh controllers e1
E1 0/0/1 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info FPGA Rev: 08121917, FPGA Type: PRK4
  Framing is CRC4, Line Code is HDB3, Clock Source is Internal.
  International Bit: 1, National Bits: 11111
  Data in current interval (858 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     21 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     21 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 2 15 minute intervals):
     0 Line Code Violations, 0 Path Code Violations,
     45 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     45 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
E1 0/1/0 is up.
  No alarms detected.
     0 Line Code Violations, 1 Path Code Violations,
     46 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
9 Replies 9
Hi ,
 did you enter the 'network-clock-select' command?
For example:
network-clock-select 1 E1 0/0/0
Hope this helps.
not yet because on my previous installations i dont have this command but I dont have slip errors.
what exactly does this command do? as far as i know this is just to prioritize which clocking should all of you E1 follow, but mine is set as internal. correct me if I am wrong, but doesnt it mean that if all E1 are internal they follow the same clock?
Always use 'network-clock-select'
Otherwise the internal clock is used, which is not that accurate compared with the providers clock (in general)
hi j.huizinga,
but i am currently using clock source internal on all my controller. so should i change all of them to line and input the 'network-clock-select'?
Yes
Always
Don't use internal unless the other end does not provide clocking
The default is line if I am not mistaken
Hi j.huizinga,
we actually tried it before but still there are slip errors found.
i will try again to set it to line with the 'network-clock-select' command and see if it will stop.
Also do i need to configure 'network-clock-select 2 E1 0/0/1' and 'network-clock-select 3 E1 0/1/0'
as a backup
Hi ejlbarcelon,
 this is an interesting document for you to read: Clock Configuration.
Hope this helps.
forgot to update, but after some troubleshooting it turns out to be a physical problem with the termination on the telco end.
