I'm trying to get EAP-TLS dot1x authentication on an IP phone to a Cisco ACS server 4.2
When i check the event logs on the ACS it just keeps saying EAP_FAST type not configured with is correct as i haven't enabled it on the ACS server.
How do you stop the IP phone using EAP_FAST.I'm using code 8-5-2SR1s on a 7970 and 7911 phone both of which do the same thing.
Am i missing something here as i can't seem to figure out if its possible to disable EAP-FAST and / or whether the iphone will then try EAP_TLS.
Cheers
Mark
