Early Media: ISDN -> SIP -> CUCM
Daniel Flieth
Hi, we have a problem with early media.
We changed the connection between cucm and gateway from H323 to SIP.
Now the customer tells us, that there is a PSTN number which played an announcement about the costs of this call. This worked with H323.
SInce we changed it to SIP, we dont get this announcemen.
To be honest, i really dont know much about early media.
Attached you see the isdn q931 debug.
As is understand, this:
Progress Ind i = 0x8488 - In-band info or appropriate now available
should indicate, that there is early media available.
Is this correct?
If there is early media, i dont know how to transfer this information via SIP to CUCM.
Does anybody know how to solve this?
Best Regards
Daniel
Mar 14 11:18:57 CET: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x24EF
        Sending Complete
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98383
                Exclusive, Channel 3
        Progress Ind i = 0x8183
SEISR1(cfg-translation-rule)# - Origination address is non-ISDN
        Calling Party Number i = 0x0180, '289XXXX'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '199XXXX'
Mar 14 11:18:57 CET: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xA4EF
Mar 14 11:18:58 CET: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0xA4EF
        Progress Ind i = 0x8482 - Destination address is non-ISDN
2 Accepted Solutions
Chris Deren
Sounds like the issue is with PRACK.  Enable PRACK on SIP Profile used by the SIP trunk in CUCM and on your CUBE.
This below link might help
https://supportforums.cisco.com/discussion/12707416/early-media-enabledisable
Find this non cisco link helpful too for understanding
https://www.dialogic.com/webhelp/IMG1010/10.5.3/WebHelp/isdn_callproceed_sip183_iw.htm
Find the below link to enable Send PRACK for all 1xx Messages from the SIP Rel1XX Options drop-down list
http://www.cisco.com/c/en/us/support/docs/voice/session-initiation-protocol-sip/116086-configure-cube-cucm-sip-00.html
You can collect debug isdn q931 and ccsip messages for the same call and post it here so if the issue still exists.
Abhay
Rate all helpful posts !!!
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Chris Deren
Thank you very much for this information, it worked immidiatly.
Abhay
Abhay Singh Reyal
