Hi, Brothers.
I´ve a Call manager express in a 2811 router with IOS version 12.4. I´ve had this platform installed since a couple of years ago but few months ago it started presenting echo in the FXO ports that I’ve configured with analog lines for communication with the PSTN. We were trying different CP tones and we diminish the echo intensity by that time, additionally we set eco canceller commands. However from some time ago the echo started again in an intermittent way when we make calls out to the PSTN. From 3 calls made, 2 have echo in the Cisco tier and the other one with no echo.
Below you can see the configuration on the FXO ports with the problem:
voice-port 0/0/0
trunk-group 1
supervisory disconnect dualtone mid-call
echo-cancel coverage 32
echo-cancel erl worst-case 3
cptone BE
timeouts call-disconnect 5
timing hookflash-out 50
connection plar 101
impedance complex2
description PBX_OFICINA BOSA
station-id number 7828470
caller-id enable
I sat tuned to any suggestion you can give me to fix this issue.
