Efax and CUCM integration
ciscovoiceguy
Hi Guys,
How to integrate between CUCM and EFAX server? I have CUCM 8.6,MGCP Voice Gateway.Any configuration steps will really be helpful
Jonathan Schulenberg
Look to your faxing vendor here for some product documentation. From CUCM's perspective it's likely just a SIP trunk to the fax server. You may need to enable T.38 fax relay on the MGCP gateway if you haven't already. You can do that from the Gateway Configuration page of the device in CUCM.
Please remember to rate helpful responses and identify helpful or correct answers.
