Enable Any Connect VPN on 88xx
csedlmeier
Dear all.
We want to enable Cisco Any Connect VPN client on our Cisco 8865.
To do this we follow the following process:
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/115785-anyconnect-vpn-00.html
We export cert. from AS and import it in to CUCM. After this it was possible to do the VPN Gateway configuration on CUCM and do VPN Profile and VPN Group configuration. After this we copy an Phone Profile and add the VPN configuration and assinge this profile to a phone and restart phone.
But we still have an issue to connect the phone by VPN to ASA.
We did some troubleshooting and it seem we have to export cert. from CUCM and import it to ASA and we have to create CAPF on the phone ?
Would be nice if yome one can help me out of this issue.
Thanks in advanced !
Christian
Jinto Alakkal
You can use either MIC (Manufacture signed) or LSC (CAPF signed), you only have to use one authentication method not both, in any of this case you have to export it from CUCM and needs to be added it as a trustpoint in ASA. Similiarly the SSL cert also needs to be exported from ASA to CUCM as VPN trust (Unified OS Administration > Security > Certificate Management > Upload Certificate > Select Phone-VPN-trust)
https://supportforums.cisco.com/t5/ip-telephony/mic-lsc-ctl-confusion/td-p/2658377 this thread is a good read about the trust certs.
Hello all.
Thanks for help it help. After checking our configuration we found out that CAPF service is not enabled on our cluster because we have no mixed mode (no encryption).
I guess it should not be an issue to enable CAPF service on the publisher to create LSC for phone ?
Or are they any issue if we do it if we have no encryption in our cluster ?
Kind regards
Christian
Hi There,
https://supportforums.cisco.com/t5/ip-telephony/understanding-capf/td-p/1556529 this link is your answer, phone finds the CAPF server through CTL installed on it and CTL files will only be generated when you place the cluster in mixed mode, you may use MIC for authentication if the cluster is not in mixed mode.
