enable POE on my L3 switch C4507-R series
Kangalala
Hi guys,
I have a working POE module of 48 ports (WS-X4248-RJ45V) on my C4503-E switch and I would like to use the module on my other switch C4507R.
The switch recognizes the POE module but it does not power my poe devices such as IPhone even after I configure the interfaces with the auto power inline config. When I put back the poe mudule on the other switch 4503 E it works normally, starting to think it has to do with hardware compatibility. Any help guys?
8 Replies 8
Mohammed Khan
Check if below bug is relevant.
 CSCef87815    C4K_SWITCHMANAGER-4-S2WERRORREPORT and POE doesnot function
Mohammed Noor
Hi Khan,
I did not understand your reply relevant to poe not functioning. Could you be more specific?
I meant check if you match the symptoms of defect CSCef87815
On Catalyst 4000/4500 series switches with 802.3af POE cards,
C4K_SWITCHMANAGER-4-S2WERRORREPORT message may be seen on console and POE
functionality
may be affected.
The following 802.3af POE cards are affected:
- WS-X4248-RJ45V
- WS-X4248-RJ21V
- WS-X4548-GB-RJ45V
- WS-X4224-RJ45V
- WS-X4524-GB-RJ45V
Problem:
Using 802.3af POE cards on Catalyst 4000/4500 series switches, phones may
never get power over ethernet and the connected links may never come up.
Disabling the POE functionality by configuring "power inline never" on a POE,
the interface can still link up when connected to non-POE devices. Few
S2WERRORREPORT messages may also be seen on the console.
Symptoms:
- C4K_SWITCHMANAGER-4-S2WERRORREPORT messages may be seen on console
- IP Phones that receive power from the connected ethernet ports of the
switch would lose power.
Workaround:
None.
Recommended Action:
Contact TAC to open a case.
Get show inventory and show module from chassis to get the exact SUP models. Then check the compatibility matrix for the module.
Also, enable term moni on the switch when you connect the module with logging level info. Monitor if any messages when you connect the module
Hi Baqari,
I will check tomorrow when I get to the office as I am already home and thanks for the reply.
Iventory & Module from the switch working POE 4503-E
NAME: "Linecard(slot 2)", DESCR: "10/100BaseTX (RJ45)V with 48 10/100 baseT voice power ports (Cisco/IEEE)"
PID: WS-X4248-RJ45V    , VID: V08, SN: JAE12056OKI
Power consumed by backplane : 0 Watts
Mod Ports Card Type                              Model              Serial No.
 1    20  Sup II+TS 10/100/1000BaseT (RJ45), SFP WS-X4013+TS        JAE12078J76
 2    48  10/100BaseTX (RJ45)V, Cisco/IEEE       WS-X4248-RJ45V     JAE12056OKI
Information from switch 4507-R that I pretend to move the Slot to.
#show version
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(25)EWA13, RELEASE SOFTWARE (fc1)
#show module
Chassis Type : WS-C4507R
Power consumed by backplane : 40 Watts
 1     2  Supervisor II+ 1000BaseX (GBIC)        WS-X4013+          JAE1217FTC8
 3     6  SFP, 10/100/1000BaseT (RJ45)V, Cisco/I WS-X4506-GB-T      JAE1132T9N8
 4    48  10/100BaseTX (RJ45)                    WS-X4148-RJ        JAE1213CD0B
 5    48  10/100BaseTX (RJ45)                    WS-X4148-RJ        JAE12056YSL
 6    48  10/100BaseTX (RJ45)                    WS-X4148-RJ        JAE120899XU
 M MAC addresses                    Hw  Fw           Sw               Status
 1 001c.581f.ec80 to 001c.581f.ec81 4.6 12.2(31r)SGA 12.2(25)EWA13    Ok
 3 0016.c75f.302e to 0016.c75f.3033 1.4                               Ok
 4 001f.9eca.e4a0 to 001f.9eca.e4cf 3.4                               Ok
 5 001f.6d2c.f660 to 001f.6d2c.f68f 3.4                               Ok
 6 001e.f72b.eb10 to 001e.f72b.eb3f 3.4                               Ok
Mod  Redundancy role     Redundancy mode     Redundancy status
 1   Active Supervisor   Non redundant       Active
SUP2 is old module and doesn't support new RJ-45 modules. This module is for support with SUP-E as per the datasheet.
For more details get the datasheet which will be of great help.
WS-X4148-RJ does NOT support PoE but WS-X4248-RJ45V does.
Can you please post the complete output to the command "sh power inline" to the chassis which has the WS-X4248-RJ45V installed.
