05-01-2013 10:56 PM - edited 03-16-2019 05:06 PM
hi. i have cisco 7945 IP phone
i want to enable single button barge in phone UI configuration............
but i am not able to select ..............?
05-02-2013 02:26 AM
Hi Sunil,
Please make sure that you are following :
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fsbarge.html
Also, please explain in more detail the exact problem you face while configuring it.
Jagpreet
05-02-2013 03:07 AM
thanks for the reply
i am trying to do the cbarge in cme i have gon through this documents...........
but not get cbarge soft key in ip Phone 7945
in the documents
"Note To use the single button barge feature, ensure that single button barge is enabled on the device.''
i have see the single button barge in phone butcurrently it is disable............
i am trying to do enable .? help me .........
05-02-2013 04:13 AM
Sunil,
I was under the impression that this was CUCM and not CME. Can you share the running configuration from the router which includes the config you have done so far for this.
Jagpreet
05-02-2013 07:30 AM
No, this is CME ..............
i will give the configuration later
05-02-2013 10:05 PM
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 1
sdspfarm tag 1 confprof1
no privacy
no auto-reg-ephone
authentication credential admin
max-ephones 165
max-dn 500
ip source-address x.x.x.5 port 2000 secondary x.x.x.6
timeouts ringing 20
system message WELCOME TO CONTINUUM
url services http://x.x.x.7/voiceview/common/login.do
url authentication http://x.x.x.5/CCMCIP/authenticate.asp
load 6945 SCCP69xx.9-1-1-0.loads
time-zone 39
voicemail 2000
max-conferences 8 gain -6
moh "music-on-hold.au"
multicast moh 239.10.16.4 port 2000 route x.x.x.5
web admin system name admin password
dn-webedit
time-webedit
transfer-system full-consult
ephone-dn 82 octo-line
number 3000
label Conventus7945
name Conventus7945
call-forward busy 2000
call-forward noan 2000 timeout 10
ephone-dn 500 dual-line
number 4001
ephone-template 5
softkeys remote-in-use CBarge Newcall
softkeys hold Resume Newcall Join
softkeys connected TrnsfVM Park Acct ConfList Confrn Endcall Trnsfer Hold
max-calls-per-button 3
busy-trigger-per-button 2
ephone 82
privacy off
mac-address 5006.xxxx.F740
ephone-template 5
username "test"
type 7945
button 1:82 2:500
05-06-2013 04:23 PM
As far as I know the main differences between Barge and cBarge are the following ones:
Barge (SIP)
- uses phone’s built-in bridge
- max 3 parties
- for SIP shared line only
cBarge (SCCP and SIP)
- SCCP octo-line
- SIP shared line
If you are using SCCP phones you will need to use cBarge, so you will need to configure not only Privacy, but also:
- A hardware conference bridge
Verify if the conference profile you have created is correctly registered with the CME by using the show sccp related commands and show dspfarm all.
- A dedicated octo-line ephone-dn for an ad-hoc conference.
Example:
ephone-dn 100 octo-line
number 8889
name CBargeConference
conference ad-hoc
More details in here
How to Configure Barge and Privacy
This section contains the following tasks:
• SCCP: Configuring the cBarge Soft Key
• SIP: Enabling Barge and cBarge Soft Keys
• SCCP: Enabling Privacy and Privacy on Hold
• SIP: Enabling Privacy and Privacy on Hold
Prerequisites
• Cisco Unified CME 7.0 or a later version.
• Octo-line directory number is configured. See the "SCCP: Creating Directory Numbers" section.
• Privacy is disabled on the phone. See the "SCCP: Enabling Privacy and Privacy on Hold" section.
• Ad hoc hardware conference resource is configured and ready to use. See"Configuring Conferencing".
• Join and leave tones for hardware conference can be configured as barge entrance and exit tones. See the "SCCP: Configuring Join and Leave Tones" section.
Restrictions
• Supported only on octo-line directory numbers.
• Not supported for meet-me conferences.
• Not supported if phone user is already connected to the same ad hoc conference on the octo-line.
I hope it helps
BR
05-06-2013 06:31 PM
Hi Sunil,
My apologies, could not get back to you earlier. As Aman pointed out, make sure you have a conference bridge configured. You can use the following document wherein the configuration and the need is explained in detail:
https://supportforums.cisco.com/docs/DOC-32808
Jagpreet
05-06-2013 11:34 PM
actully i configured all this but not able to see the soft-key in cisco 7945 phone.
In cisco 7945 setting>>> device configuration >>> UI configuration>> Single button barge is disable.
i need to enable this
Please help me
