Enabling IPv6 on 7961G
sriharithota
Hi Team,
I'm observing that ipv6 address is grayed out in 7961 ip phone. can you suggest why it is so. How can i enable it. please point me to the right source/link.
your help is much appreciated
If you're using it with CUCM, right now the only version that supports it is CCM 4.3 on Windows 2003 server. CUCM 7.1.1 should support it as well, and it will be out a few months from now.
-nick
Thank you nick for your quick response.
I'm currently using CCM4.0 on windows 2000 server. if i upgrade it to CCM4.3 on Windows 2003 and also SCCP firmware on ip phone will i be able to implement end to end setup of voip on ipv6.
I have also came to know voip on ipv6 is only supported on CUCM 7.1.1 which is not in market as of now, can you confirm it please.
Yes, I included 7.1.1 in my first post here. CCM 4.3 should support it.
-nick
