I am trying to get encryption set up for all the phones.
The whole setup for encryption on the UC520 itself appears to go fine, no errors and all the cert chains appear to be created.
However, it falls just short of registering the phone; a phone which has been fully registered and is functional without encryption.
It gets the locale and IP but then it fails with:
027676: Sep 18 19:08:12.498 EDT: New Skinny socket accepted [2] from 1, sub 1 (26 active)
027677: Sep 18 19:08:12.498 EDT: sin_family 2, sin_port 51395, in_addr x.x.x.x
027678: Sep 18 19:08:12.502 EDT: add_skinny_secure_socket: pid =337, new_sock=0, ip address = x.x.x.x
027679: Sep 18 19:08:12.502 EDT: skinny_secure_handshake: pid =337, sock=0, args->pid=337, ip address = x.x.x.x
027680: Sep 18 19:08:12.502 EDT: Start TLS Handshake 0 x.x.x.x 51395
027681: Sep 18 19:08:12.502 EDT: TLS Handshake retcode OPSSLReadWouldBlockErr
027682: Sep 18 19:08:13.502 EDT: TLS Handshake error -6992
027683: Sep 18 19:08:13.502 EDT: TLS context configuration FAILED for 0 x.x.x.x 51395
This is the basic test phone setup:
ephone 36
device-security-mode encrypted
capf-auth-str xxxx
cert-oper upgrade auth-mode auth-string
mac-address x.x.x
ephone-template 16
username "x" password x
type 7942
button 1:130
I've tried using the MIC as well, but no luck.
Any suggestions or directoins to look in?
Perhaps following link will help:
https://supportforums.cisco.com/docs/DOC-21867
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
