09-18-2017 07:44 AM - edited 03-17-2019 11:11 AM
Hi - i have recently upgraded my CUCM cluster from 8.6 to 10.5 and I have noticed all NEW users that are synced via LDAP DO NOT have the 'Home Cluster' box checked in end user page. This is affecting the users ability to login using EM.
I have found the following on the 'help about' page.
After an upgrade to Unified Communications Manager Release 10.0(1), when new users are synced from LDAP, the home cluster is not enabled. You must modify your existing LDAP synchronization agreement and add a Feature Group Template which has the home cluster enabled
I have checked the default Feature Group Template and the Home Cluster check box is enabled. How do I modify my existing LDAP synchronization agreement for this to take effect.
Solved! Go to Solution.
09-18-2017 07:54 AM
Is the feature group template assigned to your LDAP Directory?
System -> LDAP -> LDAP Directory
There will be a drop down in the Group Information section.
09-18-2017 07:54 AM
09-18-2017 08:03 AM
Ah yes! Found it, thank you :)
09-18-2017 08:04 AM
Glad to help! Please mark as helpful or resovled.
