Error 30026
s-adhikary
Hello
I am facing problem while generating the CDR report.i am using Call manager 4.1(3).I am getting the message "30026:Data is available only from Dec 27,2007,to Dec 28,2007."Though i have enabled all the parameters related with CDR generation.
gogasca
Level 10
Level 10
1 - Restart the CDR analysis and reporting scheduler service.
or
2 - Purge the ART database, so it rebuilds itself from scratch based on the current CDR
data. Follow the instructions for “cause 1” on the link below:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_n
ote09186a008056bd4e.shtml#cause1
or
3 - Uninstall the CAR application (say “yes” when asked if you want to remove the ART
database), then reboot the server and install it again
