Error Discovery PCD 10.5
hainguyen3
Dear all
I having one CUCM is Publisher and two CUCM subscriber. I want to migratio from CUCM ver 7 to CUCM ver 10.5. I used to Cisco PCD. But I discovey Cluster error.
Please help me
Aditya Gupta
The error message indicates that there is problem with OS admin credentials for cucm-02 and cucm-03.
Can you please verify if those are correct ?
Also are you using any customized log on message on the CUCM nodes ? If yes then you may be running into the following defect : CSCur45491
http://cdetsweb-prd.cisco.com/apps/dumpcr?identifier=CSCur45491&parentprogram=QDDTS
Workaround:
Need to delete the Customized Logon Messages on the application nodes
Aditya
