06-20-2013 08:39 AM - edited 03-16-2019 05:59 PM
Hello All,
Users are getting the message "if you'd like to make a call please hang up and dial again" once they pressed the answer button for inbound UCCE calls. (This is intermitted issue). Below is the call flow. Any idea is much appreciated.
FXOs-->UCCE-->IPPA phones.
Murali.P
Solved! Go to Solution.
06-21-2013 01:02 AM
Some false answer issue with analog lines, thta can require a log of debug and effort just to find exactly.
If you want a robust system use ISDN PRI, not FXO.
06-21-2013 01:02 AM
06-21-2013 02:22 AM
I suspected the same Paolo, thanks for your confirmatiom.
06-21-2013 02:37 AM
Thank you for the nice rating and good luck!
