You should enabled SIP inspection on the firewall; that will take care port openings (for both signalling and media) and SDP headers.
In addition to that, for incoming call establishment, you should allow SIP signalling ports (TCP/UDP 5060) and define the corresponding static NAT entries to point to your CUBE (if CUBE is behind NAT and not in the DMZ).
Georgios
Please rate if you find this helpful.
