01-16-2018 01:14 AM - edited 03-17-2019 11:57 AM
Hello team,
One of our customer have NEC Univerge SV8100.i need to add Cisco 3905 and 6905 phones and make working..
how can we do that??
Any document regarding that??
kindly help??
Solved! Go to Solution.
01-16-2018 02:29 AM
That is also a SIP phone. Any SIP phone should be supported, as long as your PBX supports SIP (which does).
01-16-2018 01:27 AM
If the PBX supports SIP then, yes, the Cisco 3906 should be able to register. You will just have to serve the appropriate configuration file through the TFTP server to the 3905. Find a sample SIP configuration file for a Cisco 3905 and adjust accordingly.
The second model you are referring to is not valid. In general, Cisco 69xx IP phones can be loaded with SIP firmware, so you will have to act the same way.
01-16-2018 02:25 AM
thanks for the reply..
Cisco SPA 303 ip phone support in this setup??
01-16-2018 02:29 AM
01-16-2018 02:42 AM
Can you please explain briefly the process of adding Cisco SPA 303 in NEC and make voice calls..
We need to do any configuration in NEC.
kindly reply if possible..
01-16-2018 02:45 AM
Unfortunately, I am not familiar with NEC IP PBXs. You should look into the PBX's configuration guide.
