11-24-2010 08:48 AM - edited 03-16-2019 02:05 AM
Please help to configure line appearance in expansion module ( Cisco 7915 12 button ) using CUCM.
Thanks & Regards,
Shaggy
Solved! Go to Solution.
11-24-2010 08:54 AM
Shaggy,
1. Physically attach the module to the base phone
2. In CUCM, create a Phone Button Template that places line appearances on the side car (Device>Device Settings>Phone Button Template
- You would start configuring the side car buttons at button 7
3. In CUCM, add the Expansion Module to the phone (Device>Phone)
4. In CUCM, add a line to the phone and choose one of the sidecar buttons
HTH.
Bill
Please rate helpful posts.
11-24-2010 08:54 AM
Shaggy,
HTH.
Bill
11-25-2010 08:29 AM
Hi Bill,
Your suggestion was helpful and worked, but I faced another issue as the user had two device ( 7965 & 7962 ) profiles, i added the expansion module to one device profile ( 7962 ) as the expansion module was connected to the 7962 phone, when the user tried to login it didnt prompt for which profile to login ( 7962 or 7965 ), by default it logged into 7965, i deleted the 7965 profile and user is able to view the button appearances now.
Is there a way, to include for a device profile prompt when user has more than one device profile ?
Thanks & Regards,
Shaggy.
08-23-2017 04:11 AM
