Exporting a list of only registered IP phones
nelson.chu
How can you export a list of only registered IP phones from Callmanager 4.2?  I looked into the RTMT, but it shows a total number of registered phones, but does not allow for exporting a complete list of devices to a CSV file.  When I go to SQL Server Enterprise Manager, under CCM0300, Tables, and Devices, I select Return All Rows, it shows me a lot of information, but I can't tell which device(s) is registered or not.  Lastly, while the BAT tool can generate a report of devices, it does not allow for only registered phones.
Nelson
Jaime Valencia
CCM doesn't provide a report that only has registered IP phone.
The status of the registration is gathered via RIS and that info is not stored in the DB.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Thanks for your information.  Since this is not stored in the DB, doing SQL queries would not be able to produce a list of registered devices.
Nelson
