Express way Block Ips Address
Juraj Papic
Level 3
Level 3
I have my Expressways and I would like to know how I can configure the system to block IPs from registering.
Thanks.
Ratheesh Kumar
Hi there
You should be able to block these types of calls by a combination of CPL and search rules.
Please check out this link....its helps
https://community.cisco.com/t5/telepresence-and-video/unwanted-automatic-call-hitting-on-my-expressway-e/td-p/2880056
Hope this Helps
Cheers
Rath!
***Please rate helpful posts and if applicable mark "Accept as a Solution"***
