03-17-2017 03:32 AM - edited 03-17-2019 09:50 AM
Hello all,
I have enabled auto-registration on the Call Manager, but the auto-registered phones do not have the Extension Mobility feature enabled. I have to go on each Phone and tick the box "Enable Extension Mobility"
Is there a way to enable Extension Mobility globally for phones that will be auto-registered and/or to the phones that are already auto-registered
Thank you
Theo
Solved! Go to Solution.
03-17-2017 03:46 AM
Hi Theo,
You can do it through BAT
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-version-60/112009-em-bat-config.html
(Rate if it helps)
JB
03-17-2017 04:01 AM
Hi Theo,
Unfortunately you cannot enable that option with Auto registration, so the only option you are left with if you want to do it in bulk is BAT.
JB
03-17-2017 03:46 AM
Hi Theo,
(Rate if it helps)
JB
03-17-2017 04:01 AM
Hi Theo,
JB
03-17-2017 09:58 AM
That will depend on your version, if you have Universal Device Template in auto registration settings, you absolutely can do this.
You would need to create a Universal Device Template for this, and check the Enable Extension Mobility option. Then associate it to your auto registration settings.
You can actually fine tune a lot of settings for auto registration using the Universal Device Template and Universal Line Template.
03-27-2017 02:55 AM
Perfect! Thank you Valencia
We are running
System version: 9.1.2.11900-12
I can see the Universal Device Template under User Management. I will try to give it a go.
Thank you
