Hi, I'm a newby in this field, and first time try to use this forum referred by somefriend. I wonder if I can some help as I know it might be simple question for all the expert here.
I couldn't get the Extension mobility work. I have verified several aspects :
1. CCM does has Extension mobility service started.
2. Device Profile Default was created with subscription for Extension Mobility service.
3. A device profile was created by using the device profile default.
4. A user was created in the Global Directory, and associated with the Extension Mobility service.
5. Also I have verified the model of the phone is matching on Device Profile and the phone I'm using
After all this I start to try Extension Mobility login. However after I put in User ID and password, it pop back to login page "
Authorization Required !
User Name: (I put user ID)
Password: (I Put user PIN)
Enter User Id and Password
Can some one tell me what do I miss here ? Thanks for your help !
