IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5804 Views
  • 14 replies
I have a branch office and GW with full E1 PRI circuit and connection to IP WAN. This is centralized deployment without CCME and set-up for SRST. If the GW is not communicating with CCM (i.e. IP WAN is down), the isdn status comes up fine with multi ...
If a cisco voice router has two PRI and one connects to PSTN, the other one connects to PBX, do we need DSP, why? I think DSP is only required when from IP to PRI or voice versa? Thanks
Hello all,I am looking into upgrading my CCM 4.0.2a sr2 cluster to 4.1.3. I am currently running a cluster of 4 servers (2 MCS-7835H-3000 and 2 MCS-7835H-1000). I understand that Cisco has not done extensive testing on MCS-7835H-1000 with the new ver...
dtran by Level 6
  • 233 Views
  • 1 replies
Hi;We use CM 4.1 and 2811 voice gateway. We have two FCTs. One is working properly, but another one has a problem(same vendor, same model, same config on 2811, H323 gateway).When the problematic number is called from outside, fxo port cannot transfer...
yatisspor by Level 1
  • 321 Views
  • 1 replies
Hi, I have a callmanager cluster. Pub in one site, and sub in another location each with one PRI. I have configure the gateway and route group but how do I configure the route patterns so when I dial out the call goes out using the local PRI and n...
Can someone give me some guides on how I can setup VoIp within our Company's network. I want to be able to connect all our branch offices back to our Headquarters offices and vice versa to be able to use our existing data network to carry voice traff...
bericaleb by Level 1
  • 271 Views
  • 1 replies
Hi allwe run a CM 4.2(3) with IP Phones 7960.We now ordered new phones 7961. If I have to replace an old 7960 phone is it possible to upgrade the phone to the new model (7961) or do I have to delete the old config and set up a new phone with model ty...
telefonie by Level 5
  • 537 Views
  • 1 replies
