08-05-2015 09:22 AM - edited 03-17-2019 03:53 AM
Hi Guys
Anyone seen any configuration in cucm whereby the user will be locked out of their phone profile if they enter the incorrect extension mobility username and pin incorrectly, lets say 3 times?
Anyone seen any configuration to lock the users web password for the cm user options page?
Thanks in advance
regards
Imran
Solved! Go to Solution.
08-05-2015 09:35 AM
Hi Imran,
Unfortunately such an option is not available with Extension mobility.
Manish
- Do rate helpful posts -
08-05-2015 09:36 AM
Not for PIN and EM, for password, check your credential policy settings.
08-05-2015 09:35 AM
Hi Imran,
Manish
08-05-2015 09:36 AM
04-11-2018 08:30 AM
I am having the same VoIP problem showing up at a remote site;
"Anyone seen any configuration in cucm whereby the user will be locked out of their phone profile if they enter the incorrect extension mobility username and pin incorrectly, lets say 3 times?"
I was wondering what the solution/problem was?
Thanks in advance, any help would be appreciated.
Peter
