Extension to Voice Port
Phil.Garrelhas
We currently have a Cisco 2901 CME with CUE.
I'd like to know how to create an extension (i.e. 555) and have that forward to a front door paging unit we have connected to a voice port.
The voice port's configuration is as follows.
voice-port 0/2/0
cptone CA
description Viking Front Door Paging Unit
station-id name Front Door
caller-id enable
Tommer Catlin
Create a dial-peer for this and make a match of 555.  When you dial this number it will take the analog port off hook
5 Replies 5
Tommer Catlin
So something like this:
dial-peer voice 3023 pots
destination-pattern 555
port 0/2/0
Yup, give it a try. It should work.
Yep. That worked.
Thanks!
See, we knew you could do it!
Glad it works!
