03-01-2016 10:14 AM - edited 03-17-2019 06:05 AM
External calls are taking 15 seconds
Client is complaining that the external calls are taking 15 seconds. External calls pass through a router with a e1 and also links voip pass the asterisk. Any solution for this?
Thank you.
Solved! Go to Solution.
03-01-2016 10:34 AM
I'd start by looking for overlapping in your dial plan, I'm assuming this is CUCM as you don't to mention what system you're asking about.
03-01-2016 10:49 AM
The default interdigit timeout is 15 seconds, which means there is an overlapping in your dial plan, and CUCM needs to wait those 15 seconds before making a choice to route the call.
Change the IDT timer to something else, if now you only have to wait for that X number of seconds before placing a call, then it's sure it's an overlapping dial plan, the only real fix, is to adjust your dial plan to avoid that from happening.
03-01-2016 10:34 AM
03-01-2016 10:46 AM
Good afternoon Jaime,
I did not understand your answer. What system that?
Because remake the dial plan?
The version of CallManager is 9.1.2. The gateway is a router with an e1 board. The calls continue to work, but it takes 15 seconds to start the calls.
I need solutions to this.
03-01-2016 10:49 AM
