FAC Code
ethelmtekwane
Community Member
FAC code is displayed while typed on the phone on CM 8 is the parameter you can tick to hide? I've checked the configuration its correct and the parametres on service parameter are still set to the default
Rob Huffman
Hi Ethel,
I believe this is could be due to a couple of Bug/Defects
CSCta93018            Bug Details
FAC is showing in clear text
Symptom:
While making a call outside through PSTN or Trunk and FAC is compulsary for that Route pattern and User provided the correct FAC. It is showing in clear text.
Conditions:
Workaround:
Further Problem Description:
StatusStatus
Open
Severity Severity
6 - enhancement
Last Modified Last Modified
In Last Year
Product Product
Cisco Unified IP Phones 9900 Series
Technology Technology
1st Found-In 1st Found-in
9.0(0)
CSCsb68946            Bug Details
SIP phone needs to replace digits with "*" in FAC
Symptom:
Currently, TNP phones (tested on 7970) will not block out the digits dialed for a FAC code.
Conditions:
Dialing a translation pattern with "Forced Authorization Code" from the phone will result in code digits being display on the phone while typed.
Workaround:
None.
StatusStatus
Open
Severity Severity
6 - enhancement
In Last Year
Product Product
Cisco Unified IP Phone 7900 Series
8.0(0.8)
If you are running 8900,9900 series phones new Firmware may have resolved this issue;
Cisco Unified IP Phone 8961, 9951, and 9971 (SIP) Release Notes for Firmware Release 9.2(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/9971_9951_8961/firmware/9_2_1/release_notes/9900_8900_921.html#wp219168
Forced Authentication Code and Client Matter Code Support
The Forced Authentication Code (FAC) and Client Matter Code (CMC) Support feature extends the FAC and CMC features to more Cisco Unified IP Phones.
FAC controls the types of calls that certain users can place. When placing a call, a user receives a prompt to enter a valid authorization code before the call is made.
CMC enables a user to specify that a call relates to a specific client matter. When placing a call, a user can enter a code to indicate the type of call being placed (for example, to a specific customer).
These enhancements are supported on these Cisco Unified IP Phones (SIP):
Cisco Unified IP Phone 9951
Cisco Unified IP Phone 9971
Cheers!
Rob
5 Replies 5
Rob Huffman
Hi Ethel,
Symptom:
Conditions:
Workaround:
StatusStatus
Open
Severity Severity
6 - enhancement
In Last Year
Product Product
9.0(0)
Symptom:
Conditions:
Workaround:
None.
StatusStatus
Open
Severity Severity
6 - enhancement
In Last Year
Product Product
8.0(0.8)
Cheers!
Rob
Thanks for the lead i was able to test on other phone models 7912,7911,7962 and 7961 did not experience the problem but only with 7942 SCCP
Any workaround for SCCP phones.
Rob Huffman
Hi Ethel,
Can you please provide the exact firmware the 7942's are running
Cheers!
Rob
Hello Rob,
I too has same experience in CUCM 12.0.1 with 7942 SIP phones. FAC codes are visible and stored when redial same number.
Firmware is SIP42.9-4-2SR3-1S
# I am ble to see FAC code it do not appear with *** as with SCCP mode of 7942
# FAC is stored in redial option so it do not ask again while redialing same number.
Any solution for this.
