I have a voice setup where my cisco router is connected to a analog PBX with the FXS ports. The analog phones register to the analog PBX and the PBX forwards those calls to the CME on voice ports. I need to implement FAC for restricted international calling on the CME on the router. I have tested the FAC feature in my lab and it works with analog phone directly connected to CME. My question is would the same configuration work when there is a PBX on the FXS ports and the analog phones are not directly connected the router/CME?
Below is my configuration:
voice lpcor enable
voice lpcor custom
group 10 end-users
group 11 pin-dial
voice lpcor policy end-users
service fac
accept end-users fac
accept pin-dial fac
voice lpcor policy pin-dial
service fac
accept pin-dial fac
application
package auth
param passwd-prompt flash:enter_pin.au
param max-retries 0
param user-prompt flash:enter_account.au
param term-digit #
param abort-digit *
param max-digits 32
username 666 password 0 12345
voice-port 5
lpcor incoming end-users
dial-peer voice 1234567890 pots
destination-pattern 1234567890
port 5
dial-peer voice 2 voip
destination-pattern .T
lpcor outgoing pin-dial
session protocol sipv2
session target ipv4:xxx.xxx.xxx
incoming called-number .
voice-class codec 8641
dtmf-relay cisco-rtp rtp-nte digit-drop h245-signal h245-alphanumeric
ip qos dscp ef signaling
Thanks!
