Factory Reset 8821
adelaura
I have a Cisco 8821 that display a strange error that is "MIC not installed", it's broken or I can do something for let it works?
Second question: how do I perform a factory reset on this model?
1- Mic not installed :- Find the below link helpful
http://www.cisco.com/c/en/us/support/docs/collaboration-endpoints/wireless-ip-phone-8821/201021-Troubleshoot-8821-IP-Phone-Display-MIC.html
2- Factory reset
You can reset the phone to factory defaults using the keypad. The phone resets user and network setup settings
to their default values and then restarts.
Procedure
Step 1 Press the Power/End Call and Pound (#) keys at the same time.
Step 2 When the LED on the top of the phone lights, press 1 2 3 4 5 6 7 8 9 * 0 #.
Abhay
Kindly rate all helpful posts !!!
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
6 Replies 6
2- Factory reset
Procedure
Abhay
Abhay Singh Reyal
Hi Abhay,
Thank you! You were really helpful.
Having trouble loading profile to a new 8821 wireless phone.
I load the 7925 wireless profile through my PC (192.168.1.100)
can I do the same with the 8821wireless phone
***Step 2: LED light on device will first illuminate green, when it changes to red/amber release on and # button. Proceed with 123456789*# the red LED light will flash will every button pressed. If red LED light does not flash with break code you will have to power down and follow reset instruction again.
123456789*0#
dkikko2
Follow bullet point 2 and 3..
Factory reset 8821:
Turn the phone off by pressing the red button.
• Press and hold the # key, then power on the phone.
• Keep the # key and power button held until the LED turns red.
• Once the LED changes colors, release the power and # key.
• Then press 1 2 3 4 5 6 7 8 9 * 0 #.
• The Cisco Wireless IP Phone 8821 or 8821-EX will then continue the normal boot process and have the factory settings
