Fail calling my Voicemail box internal and fail calling Auto Attendant
ashoor.patros
Hi There,
After we have moved from one service provider to another I have lost my voicemail calling and my auto attendant as I am not able to make calls any more to my voice mail number 199 internal and external and when I am calling that number using the command csim start 199 I am getting the following error
#csim start 199
csim: called number = 199, loop count = 1 ping count = 0
csim err:csim_do_test invalid major major(16) minor(0)
csim err csimDisconnected recvd DISC cid(1482)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
itirt01#
041465: Sep  3 09:29:16.031 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x8708500C) with key=[989] to table
041466: Sep  3 09:29:16.031 PCTime: //1482/000000000000/SIP/State/sipSPIChangeState: 0x8708500C : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
041467: Sep  3 09:29:16.031 PCTime: //1482/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
041468: Sep  3 09:29:16.031 PCTime: //1482/000000000000/SIP/Info/ccsip_call_setup_request: This is a TDM-IP call: callID= 1482, peer_callID = -1
041469: Sep  3 09:29:16.031 PCTime: //1482/000000000000/SIP/Info/ccsip_call_setup_request: This is a TDM-IP call: callID= 1482, peer_callID = -1
041470: Sep  3 09:29:16.031 PCTime: //1482/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 200
041471: Sep  3 09:29:16.031 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 10.1.0.2 target_port : 5060
041472: Sep  3 09:29:16.031 PCTime: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
041473: Sep  3 09:29:16.031 PCTime: //1482/42AFE9B39016/SIP/Info/ccsip_call_setup_request: Incrementing call counter in dial-peer [199]
041474: Sep  3 09:29:16.031 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
041475: Sep  3 09:29:16.031 PCTime: //1482/42AFE9B39016/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 5CA to table
041476: Sep  3 09:29:16.031 PCTime: //1482/42AFE9B39016/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
041477: Sep  3 09:29:16.031 PCTime: //1482/42AFE9B39016/SIP/Info/sipSPIGetCallConfig: Media forking disabled
041478: Sep  3 09:29:16.031 PCTime: //1482/42AFE9B39016/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
041479: Sep  3 09:29:16.031 PCTime: //1482/42AFE9B39016/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 2
041480: Sep  3 09:29:16.031 PCTime: //1482/42AFE9B39016/SIP/Media/sipSPICopyPeerDataToCCB: Firewall traversal is not enabled
041481: Sep  3 09:29:16.031 PCTime: //1482/42AFE9B39016/SIP/Info/sipSPIGetModemConfig:
From Config: Modem NSE payload = 100, Passthrough = 4, Modem relay = 0, Gw-Xid = 1
SPRT latency 200, SPRT Retries = 12, Dict Size = 1024
 String Len = 32, Compress dir = 3
041482: Sep  3 09:29:16.031 PCTime: //1482/42AFE9B39016/SIP/Info/sipSPIGetCallConfig: xcoder high-density disabled
041483: Sep  3 09:29:16.031 PCTime: //1482/42AFE9B39016/SIP/Info/sipSPIGetCallConfig: Flow Mode set to FLOW_THROUGH
041484: Sep  3 09:29:16.035 PCTime: //1482/42AFE9B39016/SIP/Info/sipSPIGetCallConfig: Media forking disabled
041485: Sep  3 09:29:16.035 PCTime: //1482/42AFE9B39016/SIP/Info/preprocessSetup:
 This is a not a SIGO Call -, could be DM call
041486: Sep  3 09:29:16.035 PCTime: //1482/42AFE9B39016/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
041487: Sep  3 09:29:16.035 PCTime: //1482/42AFE9B39016/SIP/Error/sipSPIOutgoingCallSDP: Could not create source SDP for Outgoing Call
041488: Sep  3 09:29:16.035 PCTime: //1482/42AFE9B39016/SIP/Error/sipSPICreateOutboundSDP: Error in creating an SDP for the outbound call - Check for supported codecs
041489: Sep  3 09:29:16.035 PCTime: //1482/42AFE9B39016/SIP/Error/preprocessSetup: Error during outbound SDP creation
041490: Sep  3 09:29:16.035 PCTime: //1482/42AFE9B39016/SIP/Info/ccsip_set_cc_cause_for_spi_err: Categorized cause:47, category:180
041491: Sep  3 09:29:16.035 PCTime: //1482/42AFE9B39016/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(47) for outgoing call
041492: Sep  3 09:29:16.035 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[1482], src[6]
041493: Sep  3 09:29:16.035 PCTime: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG: No Inbound Container Created !!!
041494: Sep  3 09:29:16.035 PCTime: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!!
041495: Sep  3 09:29:16.035 PCTime: //1482/42AFE9B39016/SIP/State/sipSPIChangeState: 0x8708500C : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
041496: Sep  3 09:29:16.035 PCTime: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_spi_process_ccapi_event: CCAPI Event Preprocessor Failure
041497: Sep  3 09:29:16.035 PCTime: //1482/42AFE9B39016/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
041498: Sep  3 09:29:16.035 PCTime: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
041499: Sep  3 09:29:16.035 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 7
041500: Sep  3 09:29:16.035 PCTime: //1482/42AFE9B39016/SIP/State/sipSPIChangeState: 0x8708500C : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
041501: Sep  3 09:29:16.035 PCTime: //1482/42AFE9B39016/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x8708500C
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           :
Called Number            : 199
Source IP Address (Sig  ): 0.0.0.0
Destn SIP Req Addr:Port  : :0
Destn SIP Resp Addr:Port : :0
Destination Name         :
041502: Sep  3 09:29:16.039 PCTime: //1482/42AFE9B39016/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 47
Disconnect Cause (SIP)   : 200
041503: Sep  3 09:29:16.039 PCTime: //1482/42AFE9B39016/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 5CA
041504: Sep  3 09:29:16.039 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[989] removed.
041505: Sep  3 09:29:16.039 PCTime: //1482/42AFE9B39016/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
041506: Sep  3 09:29:16.039 PCTime: //1482/42AFE9B39016/SIP/Info/ccsip_qos_cleanup: Entry
itirt01#
041507: Sep  3 09:29:16.039 PCTime: //1482/42AFE9B39016/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
041508: Sep  3 09:29:16.039 PCTime: //1482/42AFE9B39016/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 8708500C
041509: Sep  3 09:29:16.039 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[989]
I have tried many things but with no luck anyone can help please
 and this part of my running configuration
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
 modem passthrough nse codec g711alaw
 sip
  registrar server expires max 3600 min 3600
  localhost dns:itirt01
  no update-callerid
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g729r8
 codec preference 3 g711ulaw
voice class codec 2
 codec preference 1 g711ulaw
voice class codec 3
 codec preference 2 g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
voice register global
 mode cme
 max-dn 128
 max-pool 32
 create profile sync 0052122621380334
voice logout-profile 1
!sip-ua
 credentials username 029806XXXX password 7 072439157A083CXXXXrealm voice.mibroadband.com.au
 authentication username 029806XXXX password 7 01381E5D6F0A23XXXX
 no remote-party-id
 retry invite 2
 retry register 10
 timers connect 100
 registrar dns:voice.mibroadband.com.au expires 3600
 sip-server dns:trunk.engin.com.au
 connection-reuse
 host-registrar
 g729-annexb override
telephony-service
 sdspfarm units 5
 sdspfarm transcode sessions 8
 sdspfarm tag 2 itirt01t
 video
 no auto-reg-ephone
 authentication credential itadmin XXXXXXXX
 fxo hook-flash
 max-ephones 32
 max-dn 128
 ip source-address 10.1.0.1 port 2000
 max-redirect 20
 calling-number initiator
 service phone videoCapability 1
 service dnis overlay
 service dnis dir-lookup
 timeouts interdigit 2
 timeouts busy 5
 timeouts ringing 90
 system message Impact Training Institute
 url services http://10.1.0.2/voiceview/common/login.do
 url authentication http://10.1.0.1/CCMCIP/authenticate.asp
 load 7961 SCCP41.8-4-2S
 load 7970 SCCP70.8-4-2S
 time-zone 47
 date-format dd-mm-yy
 voicemail 199
 max-conferences 8 gain -6
 call-forward pattern .T
 call-forward system redirecting-expanded
 hunt-group logout HLog
 moh music-on-hold.au
 multicast moh 239.1.1.1 port 16384 route 10.1.2.1
 web admin system name impact secret 5 $1$uWF7$4hM22myBITGCUJE59SXXXXXX
 dn-webedit
 time-webedit
 transfer-system full-consult dss
 transfer-pattern 1..
 secondary-dialtone 0
 login timeout 120 clear 01:00
 directory entry 190 190 name AvT Administration
 directory entry 197 197 name Reception Queue
 directory entry 199 199 name Voice Mail
 fac custom callfwd all **1
 fac custom callfwd cancel **2
 fac custom pickup local **3
 fac custom pickup group **4
 fac custom pickup direct **5
 fac custom park **6
 fac custom dnd **7
 fac custom redial **8
 fac custom voicemail **9
 fac custom ephone-hunt join *3
 fac custom ephone-hunt cancel #3
 fac custom ephone-hunt hlog *4
 fac custom ephone-hunt hlog-phone *5
 fac custom trnsfvm *6
 create cnf-files version-stamp 7960 Jun 18 2015 16:27:38
dial-peer voice 199 voip
 description CUE Voice Mail Pilot Number
 destination-pattern 199
 monitor probe icmp-ping
 b2bua
 voice-class codec 2
 session protocol sipv2
 session target ipv4:10.1.0.2
 dtmf-relay sip-notify
 no vad
dial-peer voice 198 voip
 description CUE ITI AA Number
 destination-pattern 198
 b2bua
 voice-class codec 2
 no vad
regards,
Ash
From above post, I don't see bind command configured under voice service voip to define source interface for signaling neither on dialpeer.
Also, I don't see source interface configured on voice reigster global.
You did mention that you can't even call the voice mail internally which implies that this has nothing to do with your provider.
Please add the configs I suggested above, test a proper phone and share the output of debug ccsip mess
8 Replies 8
Adding to what Mohammed has pointed out, are you trying to reach the CUE using a SIP Phone or SCCP Phone?
Also, please verify that CUE Module is indeed online.
Thanks Wilson,
The problem that I have is that when you call main number for the office is not going to 198 which is the welcome message or what we call auto attendant number. when you call from out side to the main office numberis showing that line is busy but in fact no one is using the line and after a while you will see that is working I am not sure why is doing that ????
regards,
Ash
I can see a typo mistake in the voice register global config. The IP configured is 10.1.0.2. This is wrong it should be 10.1.0.1.
Also, take off the natting statement from loopback and ISM interfaces.
Hi Mohamad, I did fixed the type mistake and also take off the Nat in the loop interface and ism interface but the problem that I have now that I can't make call from outside sme times so sometimes it's fine and sometimes no luck . Thanks a lot for your support and time . Regards, Ash
Send the debug ccsip mess again please.
I am trying to reach CUE through out Cisco phones and through outside using SIP.
Ash
Hi Mohammed,
Thanks for that I did add the binding source in the global and under voice service voip, and that solve the internal problem I am able to call voicemail.
But now I have another problem which is I have modified my translation rule to match the number 198 which is my auto attendant and I am not able to get to the auto attendant.
Before I use to translate the main number to a direct phone number which is 101 and was ringing fine from out to that call.
I am going to post what I have done from the debug that I had and I will post my running config
056233: Sep  3 13:06:47.600 PCTime: %SEC-6-IPACCESSLOGNP: list 80 permitted 0 192.168.5.16 -> 0.0.0.0, 14 packets
itirt01(config)#
056234: Sep  3 13:06:53.888 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x87099AFC) with key=[1041] to table
056235: Sep  3 13:06:53.888 PCTime: //1602/000000000000/SIP/State/sipSPIChangeState: 0x87099AFC : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
056236: Sep  3 13:06:53.888 PCTime: //1602/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
056237: Sep  3 13:06:53.888 PCTime: //1602/000000000000/SIP/Info/ccsip_call_setup_request: This is a TDM-IP call: callID= 1602, peer_callID = 1601
056238: Sep  3 13:06:53.888 PCTime: //1602/000000000000/SIP/Info/ccsip_call_setup_request: This is a TDM-IP call: callID= 1602, peer_callID = 1601
056239: Sep  3 13:06:53.888 PCTime: //1602/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 200
056240: Sep  3 13:06:53.888 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 10.1.0.2 target_port : 5060
056241: Sep  3 13:06:53.888 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: outbound_host : 10.1.0.2 outbound_port : 5060
056242: Sep  3 13:06:53.888 PCTime: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
056243: Sep  3 13:06:53.888 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_call_setup_request: Incrementing call counter in dial-peer [198]
056244: Sep  3 13:06:53.892 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
056245: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 642 to table
056246: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
056247: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIGetCallConfig: Media forking disabled
056248: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
056249: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 2
056250: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Media/sipSPICopyPeerDataToCCB: Firewall traversal is not enabled
056251: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIGetModemConfig:
056252: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIGetCallConfig: xcoder high-density disabled
056253: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIGetCallConfig: Flow Mode set to FLOW_THROUGH
056254: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIGetCallConfig: Media forking disabled
056255: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Info/preprocessSetup:
056256: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.1.0.1
056257: Sep  3 13:06:53.892 PCTime: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 18246 for stream 1
056258: Sep  3 13:06:53.892 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
056259: Sep  3 13:06:53.892 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
056260: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
056261: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIOutgoingCallSDP: Creating recv-only stream for outbound call
056262: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
056263: Sep  3 13:06:53.892 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIProcessRtpSessions: No active streams.
056264: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Info/sip_gw_pre_setup_add_sdp_container: SDP container added
056265: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
056266: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIValidateTunnelData: RawMsg/QSIG Tunneling Not Enabled
056267: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
056268: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIShrlGetInstanceInfo: Obtained the call instance 0 for non-shared-line '198' with callid: 1602
056269: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
056270: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Error/sipSPI_ipip_set_history_info_header: Not SIP2SIP mode
056271: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Info/act_idle_continue_call_setup:
056272: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
056273: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
056274: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x87099AFC key=A9C80FFE-511F11E5-918693BD-3AE50455@itirt01
056275: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = A9C80FFE-511F11E5-918693BD-3AE50455@itirt01
056276: Sep  3 13:06:53.896 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.1.0.2,Port 5060, Transport 1, SentBy Port 5060
056277: Sep  3 13:06:53.896 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone PCTime to SIP default timezone = GMT
056278: Sep  3 13:06:53.896 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar host retrieved : voice.mibroadband.com.au
SIP: (1602) Group (a= group line) attribute, level 65535 instance 1 not found.
056279: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
056280: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Info/sipSPISendInvite: Associated container=0x897773E0 to Invite
056281: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
056282: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
056283: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Transport/sipSPITransportSendMessage: msg=0x8A4EB2D8, addr=10.1.0.2, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x80E799D8
056284: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
056285: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
056286: Sep  3 13:06:53.896 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x8A4EB2D8, addr=10.1.0.2, port=5060, connId=0 for UDP
056287: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
056288: Sep  3 13:06:53.896 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
056289: Sep  3 13:06:53.896 PCTime: //1602/A91B542B9181/SIP/State/sipSPIChangeState: 0x87099AFC : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_SENT_INVITE, SUBSTATE_NONE)
056290: Sep  3 13:06:53.900 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
056291: Sep  3 13:06:53.900 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 1602) to the VOIP RTP library
056292: Sep  3 13:06:53.900 PCTime: //1602/A91B542B9181/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
056293: Sep  3 13:06:53.900 PCTime: //1602/A91B542B9181/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.1.0.1
056294: Sep  3 13:06:53.900 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
056295: Sep  3 13:06:53.900 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.1.0.1, lport = 18246, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
src_callid = 1602, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
media_ip_addr =  - , vrf tableid = 0 media_addr_type = 1
056296: Sep  3 13:06:53.900 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
056297: Sep  3 13:06:53.900 PCTime: //1602/A91B542B9181/SIP/Info/sipSPICreateRtpSession: sess: 89DBD3F0 do_rtcp:0
056298: Sep  3 13:06:53.900 PCTime: //1602/A91B542B9181/SIP/Media/sipSPICreateRtpSession: stun is disabled
056299: Sep  3 13:06:53.900 PCTime: //1602/A91B542B9181/SIP/State/sipSPIChangeStreamState: Stream (callid =  1602)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
056300: Sep  3 13:06:53.904 PCTime: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:198@10.1.0.2:5060 SIP/2.0
Date: Thu, 03 Sep 2015 03:06:53 GMT
Call-Info: <sip:10.1.0.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
From: "AdmOpsMgr" <sip:120@voice.mibroadband.com.au>;tag=F8410B4-1AA8
Allow-Events: telephone-event
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2837140523-1360990693-2441188285-988087381
Timestamp: 1441249613
Content-Length: 252
User-Agent: Cisco-SIPGateway/IOS-12.x
To: <sip:198@10.1.0.2>
Contact: <sip:120@10.1.0.1:5060>
Expires: 180
Content-Disposition: session;handling=required
Content-Type: application/sdp
Call-ID: A9C80FFE-511F11E5-918693BD-3AE50455@itirt01
Via: SIP/2.0/UDP 10.1.0.1:5060;branch=z9hG4bK48E1318
CSeq: 101 INVITE
Max-Forwards: 70
v=0
o=CiscoSystemsSIP-GW-UserAgent 3984 6758 IN IP4 10.1.0.1
s=SIP Call
c=IN IP4 10.1.0.1
t=0 0
m=audio 18246 RTP/AVP 0 100 19
c=IN IP4 10.1.0.1
a=rtpmap:0 PCMU/8000
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:19 CN/8000
a=ptime:20
056301: Sep  3 13:06:53.920 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.1.0.2]:49856
056302: Sep  3 13:06:53.920 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
056303: Sep  3 13:06:53.920 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
056304: Sep  3 13:06:53.920 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
056305: Sep  3 13:06:53.920 PCTime: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <sip:198@10.1.0.2>;tag=cue73316ad5
CSeq: 101 INVITE
Content-Length: 0
Contact: <sip:198@10.1.0.2:5060>
056306: Sep  3 13:06:53.920 PCTime: //1602/A91B542B9181/SIP/Info/sipSPICheckResponse: INVITE response with no RSEQ - disable IS_REL1XX
056307: Sep  3 13:06:53.920 PCTime: //1602/A91B542B9181/SIP/State/sipSPIChangeState: 0x87099AFC : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
056308: Sep  3 13:06:53.976 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.1.0.2]:49856
056309: Sep  3 13:06:53.976 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
056310: Sep  3 13:06:53.976 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
056311: Sep  3 13:06:53.976 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
056312: Sep  3 13:06:53.980 PCTime: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
056313: Sep  3 13:06:53.980 PCTime: //1602/A91B542B9181/SIP/Info/sipSPICheckResponse: INVITE response with no RSEQ - disable IS_REL1XX
056314: Sep  3 13:06:53.980 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
056315: Sep  3 13:06:53.980 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentSDP: No SDP found in inbound container
056316: Sep  3 13:06:53.980 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_api_call_alert: SDP Body either absent or ignored in 180 RINGING:- will wait for 200 OK to do negotiation.
056317: Sep  3 13:06:53.980 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
056318: Sep  3 13:06:53.980 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
056319: Sep  3 13:06:53.980 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
056320: Sep  3 13:06:53.980 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
056321: Sep  3 13:06:53.980 PCTime: //1602/A91B542B9181/SIP/Info/HandleSIP1xxRinging: ccsip_api_call_alert returned: SIP_SUCCESS
056322: Sep  3 13:06:53.980 PCTime: //1602/A91B542B9181/SIP/State/sipSPIChangeState: 0x87099AFC : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
056323: Sep  3 13:06:53.980 PCTime: //1602/A91B542B9181/SIP/Info/HandleSIP1xxRinging: Transaction Complete. Lock on Facilities released.
056324: Sep  3 13:06:54.072 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.1.0.2]:49856
056325: Sep  3 13:06:54.072 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
056326: Sep  3 13:06:54.072 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
056327: Sep  3 13:06:54.076 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
056328: Sep  3 13:06:54.076 PCTime: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 170
Call-Info: <sip:10.1.0.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
v=0
o=CiscoSystemsSIP-Workflow-App-UserAgent 2241 2241 IN IP4 10.1.0.2
s=SIP Call
c=IN IP4 10.1.0.2
t=0 0
m=audio 16898 RTP/AVP 0
a=rtpmap:0 pcmu/8000
a=ptime:20
056329: Sep  3 13:06:54.076 PCTime: //1602/A91B542B9181/SIP/Info/sipSPICheckResponse: INVITE response with no RSEQ - disable IS_REL1XX
056330: Sep  3 13:06:54.076 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
056331: Sep  3 13:06:54.076 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIhandle200OKInvite: Transaction active. Facilities will be queued.
056332: Sep  3 13:06:54.076 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIhandle200OKInvite: *** This ccb is the parent
056333: Sep  3 13:06:54.076 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIProcessNotifyCallInfoHeader: Callinfo parsed - Destination url = <sip:10.1.0.2:5060>, duration = 2000
056334: Sep  3 13:06:54.076 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
056335: Sep  3 13:06:54.076 PCTime: //1602/A91B542B9181/SIP/Info/sipSPICompareRespMediaInfo: No Comparsion needed as 18x response SDP is either absent or ignored
056336: Sep  3 13:06:54.076 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
SIP: Attribute mid, level 1 instance 1 not found.
056337: Sep  3 13:06:54.076 PCTime: //1602/A91B542B9181/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
056338: Sep  3 13:06:54.076 PCTime: //1602/A91B542B9181/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.1.0.1
056339: Sep  3 13:06:54.076 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
056340: Sep  3 13:06:54.076 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
056341: Sep  3 13:06:54.076 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
056342: Sep  3 13:06:54.076 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
056343: Sep  3 13:06:54.076 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
056344: Sep  3 13:06:54.076 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
056345: Sep  3 13:06:54.076 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x870AB318) with key=[1042] to table
056346: Sep  3 13:06:54.076 PCTime: //0/000000000000/SIP/Info/ccsip_new_scb: Created new scb: 0x870AB318 with id: -1
056347: Sep  3 13:06:54.076 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_edb: Created new edb(0x870AF47C)
056348: Sep  3 13:06:54.080 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateEDBEvent: EDB updated with Event Name: telephone-event Event ID:
056349: Sep  3 13:06:54.080 PCTime: //0/000000000000/SIP/Info/ccsip_create_implicit_subscribe_dialog: Q'd EDB(0x870AF47C) on SCB(0x870AB318)
056350: Sep  3 13:06:54.080 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : A9C80FFE-511F11E5-918693BD-3AE50455@itirt01F8410B4-1AA8
056351: Sep  3 13:06:54.080 PCTime: //0/000000000000/SIP/Info/sipSPIPutSCBInClientTable: Inserting SCB with key A9C80FFE-511F11E5-918693BD-3AE50455@itirt01F8410B4-1AA8 into ClientTable
056352: Sep  3 13:06:54.080 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_create_implicit_subscribe_dialog: Changing from State: SUBSCRIBE_STATE_IDLE to state SUBSCRIBE_STATE_ACTIVE
056353: Sep  3 13:06:54.080 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
056354: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
056355: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
056356: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=sip-notify
stream_type=voice-only (0), dest_ip_address=10.1.0.2, dest_port=16898
056357: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
056358: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec        : g711ulaw, bytes :160
Preferred  DTMF relay  : sip-notify
Preferred NTE payload  : 101
Early Media            : No
Delayed Media          : No
Bridge Done            : No
New Media              : No
DSP DNLD Reqd          : No
056359: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
056360: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.1.0.1
056361: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIUpdCallWithSdpInfo:
 Stream type            : voice-only
 Media line             : 1
 State                  : STREAM_ADDING (2)
 Stream address type    : 1
 Callid                 : 1602
 Negotiated Codec       : g711ulaw, bytes :160
 Nego. Codec payload    : 0 (tx), 0 (rx)
 Negotiated DTMF relay  : sip-notify
 Negotiated NTE payload : 0 (tx), 0 (rx)
 Negotiated CN payload  : 0
 Media Srce Addr/Port   : [10.1.0.1]:18246
 Media Dest Addr/Port   : [10.1.0.2]:16898
056362: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
056363: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connect_media returned: SIP_SUCCESS
056364: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/State/sipSPIChangeState: 0x87099AFC : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
056365: Sep  3 13:06:54.080 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
056366: Sep  3 13:06:54.080 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
056367: Sep  3 13:06:54.080 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
056368: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIShrlCall: Check peer: 198 for Shared-Line call, callid: 1602
056369: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connected returned: SIP_SUCCESS
056370: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
056371: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
056372: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Transport/sipSPITransportSendMessage: msg=0x89D92CF0, addr=10.1.0.2, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x80E7B120
056373: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
056374: Sep  3 13:06:54.080 PCTime: //1602/A91B542B9181/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
056375: Sep  3 13:06:54.084 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x89D92CF0, addr=10.1.0.2, port=5060, connId=0 for UDP
056376: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/State/sipSPIChangeState: 0x87099AFC : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
056377: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x87099AFC
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 120
Called Number            : 198
Source IP Address (Sig  ): 10.1.0.1
Destn SIP Req Addr:Port  : 10.1.0.2:5060
Destn SIP Resp Addr:Port : 10.1.0.2:5060
Destination Name         : 10.1.0.2
056378: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec Bytes   : 160
Negotiated Dtmf-relay    : 8
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 10.1.0.1
Source IP Port    (Media): 18246
Destn  IP Address (Media): 10.1.0.2
Destn  IP Port    (Media): 16898
Orig Destn IP Address:Port (Media): [ - ]:0
056379: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Info/sipSPICallActive: Transaction Complete. Lock on Facilities released.
056380: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
056381: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_bridge: confID = 133, srcCallID = 1602, dstCallID = 1601
056382: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 1602/1601
056383: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=1602, new streamcallid=1602
056384: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-TDM
056385: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_bridge: xcoder_attached = 0, xmitFunc = -2141369732, ccb xmitFunc = -2141369732
056386: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
056387: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice-only (callid 1602) to the VOIP RTP library
056388: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
056389: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.1.0.1
056390: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
056391: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.1.0.1, lport = 18246, raddr = 10.1.0.2, rport=16898, do_rtcp=TRUE
src_callid = 1602, dest_callid = 1601, stream type = voice-only, stream direction = SENDRECV
media_ip_addr = 10.1.0.2, vrf tableid = 0 media_addr_type = 1
056392: Sep  3 13:06:54.084 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
056393: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:89DD3040
056394: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Info/sipSPICreateAndStartRtpTimer:
056395: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Info/sipSPICreateAndStartRtpTimer: Valid RTP/RTCP session found and CLI enabled to create and start the inactivity timer.
056396: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity timer created for stream 1.
 Mfactor(from CLI): 30  RTCP bandwidth: 500
 RTCP Interval(in ms): 5000
 Normalized RTCP interval  (in ms):150000
056397: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIGetNewLocalMediaDirection:
New Remote Media Direction = SENDRECV
Present Local Media Direction = SENDRECV
New Local Media Direction = SENDRECV
retVal = 0
056398: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/State/sipSPIChangeStreamState: Stream (callid =  1602)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
056399: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_caps_ind: Entry
056400: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=1602, current_seq_num=0x1953
056401: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=1602, current_seq_num=0x22A6
056402: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_caps_ind: Load DSP with negotiated codec: g711ulaw, Bytes=160
056403: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_caps_ind: Set forking flag to 0x0
056404: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_OUT_OF_BAND
056405: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
056406: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
056407: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
056408: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
itirt01(config)#
056418: Sep  3 13:06:54.088 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_caps_ack: Set forking flag to 0x0
056419: Sep  3 13:06:54.092 PCTime: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:198@10.1.0.2:5060 SIP/2.0
Content-Length: 0
Via: SIP/2.0/UDP 10.1.0.1:5060;branch=z9hG4bK48F1251
CSeq: 101 ACK
Max-Forwards: 70
itirt01(config)#
056420: Sep  3 13:06:56.132 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=1602, proc_id=9
itirt01(config)#
056421: Sep  3 13:06:58.632 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=1602, proc_id=9
056422: Sep  3 13:06:59.532 PCTime: //1602/A91B542B9181/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:89DD3040
056423: Sep  3 13:06:59.536 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_call_statistics: Requesting stats for callid=1602
056424: Sep  3 13:06:59.536 PCTime: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
056425: Sep  3 13:06:59.536 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=1602, proc_id=1
056426: Sep  3 13:06:59.540 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 7
056427: Sep  3 13:06:59.540 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
056428: Sep  3 13:06:59.540 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
056429: Sep  3 13:06:59.540 PCTime: //1602/A91B542B9181/SIP/Info/sipSPISendBye: Associated container=0x89776DB0 to Bye
056430: Sep  3 13:06:59.540 PCTime: //1602/A91B542B9181/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
056431: Sep  3 13:06:59.540 PCTime: //1602/A91B542B9181/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
056432: Sep  3 13:06:59.540 PCTime: //1602/A91B542B9181/SIP/Transport/sipSPITransportSendMessage: msg=0x8A41B5A8, addr=10.1.0.2, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x80E7A978
056433: Sep  3 13:06:59.540 PCTime: //1602/A91B542B9181/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
056434: Sep  3 13:06:59.540 PCTime: //1602/A91B542B9181/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
056435: Sep  3 13:06:59.540 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x8A41B5A8, addr=10.1.0.2, port=5060, connId=0 for UDP
056436: Sep  3 13:06:59.540 PCTime: //1602/A91B542B9181/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
056437: Sep  3 13:06:59.540 PCTime: //1602/A91B542B9181/SIP/State/sipSPIChangeState: 0x87099AFC : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
056438: Sep  3 13:06:59.544 PCTime: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:198@10.1.0.2:5060 SIP/2.0
Reason: Q.850;cause=16
Timestamp: 1441249619
Content-Length: 0
Via: SIP/2.0/UDP 10.1.0.1:5060;branch=z9hG4bK4901B48
CSeq: 102 BYE
Max-Forwards: 70
056439: Sep  3 13:06:59.560 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.1.0.2]:49856
056440: Sep  3 13:06:59.560 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
056441: Sep  3 13:06:59.560 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
056442: Sep  3 13:06:59.560 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
056443: Sep  3 13:06:59.560 PCTime: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 BYE
Content-Length: 0
056444: Sep  3 13:06:59.564 PCTime: //1602/A91B542B9181/SIP/Info/sipSPICheckResponse: non-INVITE response with no RSEQ - do not disable IS_REL1XX
056445: Sep  3 13:06:59.564 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:26031893 ConnTime 26031345
056446: Sep  3 13:06:59.564 PCTime: //1602/A91B542B9181/SIP/State/sipSPIChangeState: 0x87099AFC : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
056447: Sep  3 13:06:59.564 PCTime: //1602/A91B542B9181/SIP/Call/sipSPICallInfo:
Called Number            : 198
056448: Sep  3 13:06:59.564 PCTime: //1602/A91B542B9181/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
056449: Sep  3 13:06:59.564 PCTime: //1602/A91B542B9181/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 16
056450: Sep  3 13:06:59.564 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 642
056451: Sep  3 13:06:59.564 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1041] removed.
056452: Sep  3 13:06:59.564 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
056453: Sep  3 13:06:59.564 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x87099AFC key=A9C80FFE-511F11E5-918693BD-3AE50455@itirt01
056454: Sep  3 13:06:59.564 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
056455: Sep  3 13:06:59.564 PCTime: //1602/A91B542B9181/SIP/Info/ccsip_qos_cleanup: Entry
056456: Sep  3 13:06:59.564 PCTime: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
056457: Sep  3 13:06:59.564 PCTime: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
056458: Sep  3 13:06:59.564 PCTime: //1602/A91B542B9181/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
056459: Sep  3 13:06:59.564 PCTime: //1602/A91B542B9181/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 87099AFC
056460: Sep  3 13:06:59.564 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[1041]
056461: Sep  3 13:06:59.564 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 210
056462: Sep  3 13:06:59.564 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_SUBSCRIPTION_TERMINATED] received in State [SUBSCRIBE_STATE_ACTIVE]
056463: Sep  3 13:06:59.564 PCTime: //0/000000000000/SIP/Info/act_subscription_terminated: Resetting server EDB flag
056464: Sep  3 13:06:59.564 PCTime: //0/000000000000/SIP/Info/sipSPITerminateEvent: 1 Events still active on this Subscription Dialog
056465: Sep  3 13:06:59.564 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 210
056466: Sep  3 13:06:59.564 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_SUBSCRIPTION_TERMINATED] received in State [SUBSCRIBE_STATE_ACTIVE]
056467: Sep  3 13:06:59.564 PCTime: //0/000000000000/SIP/Info/act_subscription_terminated: Resetting Client EDB flag
056468: Sep  3 13:06:59.564 PCTime: //0/000000000000/SIP/Info/sipSPIFreeOneEDB: There are 1 EDBs on edbQ
056469: Sep  3 13:06:59.568 PCTime: //0/000000000000/SIP/Info/sipSPIFreeOneEDB: DeQ'd EDB(0x870AF47C)
056470: Sep  3 13:06:59.568 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneEDB: EnQing EDB(0x870AF47C) for reuse
056471: Sep  3 13:06:59.568 PCTime: //0/000000000000/SIP/Info/sipSPITerminateEvent: Freeing SCB(0x870AB318), 0 active events present
itirt01(config)#
056472: Sep  3 13:06:59.568 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1042] removed.
056473: Sep  3 13:06:59.568 PCTime: //0/000000000000/SIP/Info/sipSPIRemoveSCBFromClientTable: Removing SCB(0x870AB318) with Key(A9C80FFE-511F11E5-918693BD-3AE50455@itirt01F8410B4-1AA8) from Client Table
056474: Sep  3 13:06:59.568 PCTime: //0/000000000000/SIP/Info/sipSPIFreeOneSCB: EnQing SCB(0x870AB318) for reuse
itirt01(config)#
056475: Sep  3 13:07:17.757 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x8706B260) with key=[1043] to table
056476: Sep  3 13:07:17.757 PCTime: //1604/000000000000/SIP/State/sipSPIChangeState: 0x8706B260 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
056477: Sep  3 13:07:17.757 PCTime: //1604/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
056478: Sep  3 13:07:17.757 PCTime: //1604/000000000000/SIP/Info/ccsip_call_setup_request: This is a TDM-IP call: callID= 1604, peer_callID = 1603
056479: Sep  3 13:07:17.757 PCTime: //1604/000000000000/SIP/Info/ccsip_call_setup_request: This is a TDM-IP call: callID= 1604, peer_callID = 1603
056480: Sep  3 13:07:17.757 PCTime: //1604/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 200
056481: Sep  3 13:07:17.757 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 10.1.0.2 target_port : 5060
056482: Sep  3 13:07:17.757 PCTime: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
056483: Sep  3 13:07:17.757 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_call_setup_request: Incrementing call counter in dial-peer [199]
056484: Sep  3 13:07:17.761 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
056485: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 644 to table
056486: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
056487: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIGetCallConfig: Media forking disabled
056488: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
056489: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 2
056490: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPICopyPeerDataToCCB: Firewall traversal is not enabled
056491: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIGetModemConfig:
056492: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIGetCallConfig: xcoder high-density disabled
056493: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIGetCallConfig: Flow Mode set to FLOW_THROUGH
056494: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIGetCallConfig: Media forking disabled
056495: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/preprocessSetup:
056496: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
056497: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.1.0.1
056498: Sep  3 13:07:17.761 PCTime: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 17852 for stream 1
056499: Sep  3 13:07:17.761 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
056500: Sep  3 13:07:17.761 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
056501: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
056502: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIOutgoingCallSDP: Creating recv-only stream for outbound call
056503: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
056504: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIProcessRtpSessions: No active streams.
056505: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sip_gw_pre_setup_add_sdp_container: SDP container added
056506: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
056507: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIValidateTunnelData: RawMsg/QSIG Tunneling Not Enabled
056508: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
056509: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIShrlGetInstanceInfo: Obtained the call instance 0 for non-shared-line '199' with callid: 1604
056510: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
056511: Sep  3 13:07:17.761 PCTime: //1604/B74B0BC89187/SIP/Error/sipSPI_ipip_set_history_info_header: Not SIP2SIP mode
056512: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Info/act_idle_continue_call_setup:
056513: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
056514: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
056515: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x8706B260 key=B802280C-511F11E5-918C93BD-3AE50455@itirt01
056516: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = B802280C-511F11E5-918C93BD-3AE50455@itirt01
056517: Sep  3 13:07:17.765 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.1.0.2,Port 5060, Transport 1, SentBy Port 5060
056518: Sep  3 13:07:17.765 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone PCTime to SIP default timezone = GMT
056519: Sep  3 13:07:17.765 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar host retrieved : voice.mibroadband.com.au
SIP: (1604) Group (a= group line) attribute, level 65535 instance 1 not found.
056520: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
056521: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPISendInvite: Associated container=0x897773E0 to Invite
056522: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
056523: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
056524: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Transport/sipSPITransportSendMessage: msg=0x8A414054, addr=10.1.0.2, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x80E799D8
056525: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
056526: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
056527: Sep  3 13:07:17.765 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x8A414054, addr=10.1.0.2, port=5060, connId=0 for UDP
056528: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
056529: Sep  3 13:07:17.765 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
056530: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/State/sipSPIChangeState: 0x8706B260 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_SENT_INVITE, SUBSTATE_NONE)
056531: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
056532: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 1604) to the VOIP RTP library
056533: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
056534: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.1.0.1
056535: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
056536: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.1.0.1, lport = 17852, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
src_callid = 1604, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
056537: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
056538: Sep  3 13:07:17.765 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPICreateRtpSession: sess: 89DBD3F0 do_rtcp:0
056539: Sep  3 13:07:17.769 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPICreateRtpSession: stun is disabled
056540: Sep  3 13:07:17.769 PCTime: //1604/B74B0BC89187/SIP/State/sipSPIChangeStreamState: Stream (callid =  1604)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
056541: Sep  3 13:07:17.773 PCTime: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:199@10.1.0.2:5060 SIP/2.0
Date: Thu, 03 Sep 2015 03:07:17 GMT
From: "AdmOpsMgr" <sip:120@voice.mibroadband.com.au>;tag=F846DF0-104F
Min-SE:  1800
Cisco-Guid: 3075148744-1360990693-2441581501-988087381
Timestamp: 1441249637
Content-Length: 228
To: <sip:199@10.1.0.2>
Expires: 180
Call-ID: B802280C-511F11E5-918C93BD-3AE50455@itirt01
Via: SIP/2.0/UDP 10.1.0.1:5060;branch=z9hG4bK49118C9
CSeq: 101 INVITE
Max-Forwards: 70
v=0
o=CiscoSystemsSIP-GW-UserAgent 4485 9414 IN IP4 10.1.0.1
s=SIP Call
c=IN IP4 10.1.0.1
t=0 0
m=audio 17852 RTP/AVP 0 100
c=IN IP4 10.1.0.1
a=fmtp:100 192-194
a=ptime:20
056542: Sep  3 13:07:17.793 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.1.0.2]:49856
056543: Sep  3 13:07:17.793 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
056544: Sep  3 13:07:17.793 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
056545: Sep  3 13:07:17.793 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
056546: Sep  3 13:07:17.793 PCTime: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <sip:199@10.1.0.2>;tag=cue431ac818
CSeq: 101 INVITE
Content-Length: 0
Contact: <sip:199@10.1.0.2:5060>
056547: Sep  3 13:07:17.793 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPICheckResponse: INVITE response with no RSEQ - disable IS_REL1XX
056548: Sep  3 13:07:17.793 PCTime: //1604/B74B0BC89187/SIP/State/sipSPIChangeState: 0x8706B260 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
056549: Sep  3 13:07:17.841 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.1.0.2]:49856
056550: Sep  3 13:07:17.841 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
056551: Sep  3 13:07:17.841 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
056552: Sep  3 13:07:17.845 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
056553: Sep  3 13:07:17.845 PCTime: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
056554: Sep  3 13:07:17.845 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPICheckResponse: INVITE response with no RSEQ - disable IS_REL1XX
056555: Sep  3 13:07:17.845 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
056556: Sep  3 13:07:17.845 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentSDP: No SDP found in inbound container
056557: Sep  3 13:07:17.845 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_api_call_alert: SDP Body either absent or ignored in 180 RINGING:- will wait for 200 OK to do negotiation.
056558: Sep  3 13:07:17.845 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
056559: Sep  3 13:07:17.845 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
056560: Sep  3 13:07:17.845 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
056561: Sep  3 13:07:17.845 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
056562: Sep  3 13:07:17.845 PCTime: //1604/B74B0BC89187/SIP/Info/HandleSIP1xxRinging: ccsip_api_call_alert returned: SIP_SUCCESS
056563: Sep  3 13:07:17.845 PCTime: //1604/B74B0BC89187/SIP/State/sipSPIChangeState: 0x8706B260 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
056564: Sep  3 13:07:17.845 PCTime: //1604/B74B0BC89187/SIP/Info/HandleSIP1xxRinging: Transaction Complete. Lock on Facilities released.
056565: Sep  3 13:07:17.905 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.1.0.2]:49856
056566: Sep  3 13:07:17.905 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
056567: Sep  3 13:07:17.905 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
056568: Sep  3 13:07:17.905 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
056569: Sep  3 13:07:17.905 PCTime: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 170
v=0
o=CiscoSystemsSIP-Workflow-App-UserAgent 1550 1550 IN IP4 10.1.0.2
s=SIP Call
c=IN IP4 10.1.0.2
t=0 0
m=audio 16896 RTP/AVP 0
a=ptime:20
056570: Sep  3 13:07:17.905 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPICheckResponse: INVITE response with no RSEQ - disable IS_REL1XX
056571: Sep  3 13:07:17.909 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
056572: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIhandle200OKInvite: Transaction active. Facilities will be queued.
056573: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIhandle200OKInvite: *** This ccb is the parent
056574: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIProcessNotifyCallInfoHeader: Callinfo parsed - Destination url = <sip:10.1.0.2:5060>, duration = 2000
056575: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
056576: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPICompareRespMediaInfo: No Comparsion needed as 18x response SDP is either absent or ignored
056577: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
056578: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
056579: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.1.0.1
056580: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
056581: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
056582: Sep  3 13:07:17.909 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
056583: Sep  3 13:07:17.909 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
056584: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
056585: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
056586: Sep  3 13:07:17.909 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x870ABADC) with key=[1044] to table
056587: Sep  3 13:07:17.909 PCTime: //0/000000000000/SIP/Info/ccsip_new_scb: Created new scb: 0x870ABADC with id: -1
056588: Sep  3 13:07:17.909 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_edb: Created new edb(0x870AF5F8)
056589: Sep  3 13:07:17.909 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateEDBEvent: EDB updated with Event Name: telephone-event Event ID:
056590: Sep  3 13:07:17.909 PCTime: //0/000000000000/SIP/Info/ccsip_create_implicit_subscribe_dialog: Q'd EDB(0x870AF5F8) on SCB(0x870ABADC)
056591: Sep  3 13:07:17.909 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : B802280C-511F11E5-918C93BD-3AE50455@itirt01F846DF0-104F
056592: Sep  3 13:07:17.909 PCTime: //0/000000000000/SIP/Info/sipSPIPutSCBInClientTable: Inserting SCB with key B802280C-511F11E5-918C93BD-3AE50455@itirt01F846DF0-104F into ClientTable
056593: Sep  3 13:07:17.909 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_create_implicit_subscribe_dialog: Changing from State: SUBSCRIBE_STATE_IDLE to state SUBSCRIBE_STATE_ACTIVE
056594: Sep  3 13:07:17.909 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
056595: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
056596: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
056597: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
stream_type=voice-only (0), dest_ip_address=10.1.0.2, dest_port=16896
056598: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
056599: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIUpdCallWithSdpInfo:
Early Media            : No
Delayed Media          : No
Bridge Done            : No
New Media              : No
DSP DNLD Reqd          : No
056600: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
056601: Sep  3 13:07:17.909 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.1.0.1
056602: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIUpdCallWithSdpInfo:
 Media line             : 1
 Callid                 : 1604
 Media Srce Addr/Port   : [10.1.0.1]:17852
 Media Dest Addr/Port   : [10.1.0.2]:16896
056603: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
056604: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connect_media returned: SIP_SUCCESS
056605: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/State/sipSPIChangeState: 0x8706B260 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
056606: Sep  3 13:07:17.913 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
056607: Sep  3 13:07:17.913 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
056608: Sep  3 13:07:17.913 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
056609: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIShrlCall: Check peer: 199 for Shared-Line call, callid: 1604
056610: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connected returned: SIP_SUCCESS
056611: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
056612: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
056613: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/Transport/sipSPITransportSendMessage: msg=0x89E190A0, addr=10.1.0.2, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x80E7B120
056614: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
056615: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
056616: Sep  3 13:07:17.913 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x89E190A0, addr=10.1.0.2, port=5060, connId=0 for UDP
056617: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/State/sipSPIChangeState: 0x8706B260 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
056618: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x8706B260
Called Number            : 199
056619: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 17852
Destn  IP Port    (Media): 16896
056620: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPICallActive: Transaction Complete. Lock on Facilities released.
056621: Sep  3 13:07:17.913 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
056622: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_bridge: confID = 134, srcCallID = 1604, dstCallID = 1603
056623: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 1604/1603
056624: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=1604, new streamcallid=1604
056625: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-TDM
056626: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_bridge: xcoder_attached = 0, xmitFunc = -2141369732, ccb xmitFunc = -2141369732
056627: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
056628: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice-only (callid 1604) to the VOIP RTP library
056629: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
056630: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.1.0.1
056631: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
056632: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.1.0.1, lport = 17852, raddr = 10.1.0.2, rport=16896, do_rtcp=TRUE
src_callid = 1604, dest_callid = 1603, stream type = voice-only, stream direction = SENDRECV
056633: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
056634: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8A4CB49C
056635: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPICreateAndStartRtpTimer:
056636: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPICreateAndStartRtpTimer: Valid RTP/RTCP session found and CLI enabled to create and start the inactivity timer.
056637: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity timer created for stream 1.
056638: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIGetNewLocalMediaDirection:
retVal = 0
056639: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/State/sipSPIChangeStreamState: Stream (callid =  1604)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
056640: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_caps_ind: Entry
056641: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=1604, current_seq_num=0x39B
056642: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=1604, current_seq_num=0xFD6
056643: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_caps_ind: Load DSP with negotiated codec: g711ulaw, Bytes=160
056644: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_caps_ind: Set forking flag to 0x0
056645: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_OUT_OF_BAND
056646: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
056647: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
056648: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
056649: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
056650: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=2, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
056651: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
056652: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice-only) from media
line 1 codec g711ulaw
056653: Sep  3 13:07:17.917 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=1,caps.stream[0].stream_type=0x1, caps.stream_list.xmitFunc=
itirt01(config)#
056659: Sep  3 13:07:17.921 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_caps_ack: Set forking flag to 0x0
056660: Sep  3 13:07:17.925 PCTime: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:199@10.1.0.2:5060 SIP/2.0
Content-Length: 0
Via: SIP/2.0/UDP 10.1.0.1:5060;branch=z9hG4bK49215C9
CSeq: 101 ACK
Max-Forwards: 70
itirt01(config)#
056661: Sep  3 13:07:19.665 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=1604, proc_id=9
itirt01(config)#
056662: Sep  3 13:07:21.869 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=1604, proc_id=9
itirt01(config)#
056663: Sep  3 13:07:25.609 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=1604, proc_id=9
056664: Sep  3 13:07:26.541 PCTime: //1604/B74B0BC89187/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8A4CB49C
056665: Sep  3 13:07:26.545 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_call_statistics: Requesting stats for callid=1604
056666: Sep  3 13:07:26.549 PCTime: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
056667: Sep  3 13:07:26.553 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=1604, proc_id=1
056668: Sep  3 13:07:26.557 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 7
056669: Sep  3 13:07:26.557 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
056670: Sep  3 13:07:26.557 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
056671: Sep  3 13:07:26.557 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPISendBye: Associated container=0x89776B48 to Bye
056672: Sep  3 13:07:26.557 PCTime: //1604/B74B0BC89187/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
056673: Sep  3 13:07:26.557 PCTime: //1604/B74B0BC89187/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
056674: Sep  3 13:07:26.557 PCTime: //1604/B74B0BC89187/SIP/Transport/sipSPITransportSendMessage: msg=0x8A290C78, addr=10.1.0.2, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x80E7A978
056675: Sep  3 13:07:26.557 PCTime: //1604/B74B0BC89187/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
056676: Sep  3 13:07:26.557 PCTime: //1604/B74B0BC89187/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
056677: Sep  3 13:07:26.557 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x8A290C78, addr=10.1.0.2, port=5060, connId=0 for UDP
056678: Sep  3 13:07:26.557 PCTime: //1604/B74B0BC89187/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
056679: Sep  3 13:07:26.557 PCTime: //1604/B74B0BC89187/SIP/State/sipSPIChangeState: 0x8706B260 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
056680: Sep  3 13:07:26.561 PCTime: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:199@10.1.0.2:5060 SIP/2.0
Timestamp: 1441249646
Content-Length: 0
Via: SIP/2.0/UDP 10.1.0.1:5060;branch=z9hG4bK4939BF
CSeq: 102 BYE
Max-Forwards: 70
056681: Sep  3 13:07:26.577 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.1.0.2]:49856
056682: Sep  3 13:07:26.577 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
056683: Sep  3 13:07:26.577 PCTime: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
056684: Sep  3 13:07:26.577 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
056685: Sep  3 13:07:26.577 PCTime: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 BYE
Content-Length: 0
056686: Sep  3 13:07:26.577 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPICheckResponse: non-INVITE response with no RSEQ - do not disable IS_REL1XX
056687: Sep  3 13:07:26.581 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:26034594 ConnTime 26033728
056688: Sep  3 13:07:26.581 PCTime: //1604/B74B0BC89187/SIP/State/sipSPIChangeState: 0x8706B260 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
056689: Sep  3 13:07:26.581 PCTime: //1604/B74B0BC89187/SIP/Call/sipSPICallInfo:
State of The Call        : STATE_DEAD
Called Number            : 199
056690: Sep  3 13:07:26.581 PCTime: //1604/B74B0BC89187/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
056691: Sep  3 13:07:26.581 PCTime: //1604/B74B0BC89187/SIP/Call/sipSPICallInfo:
Disconnect Cause (SIP)   : 200
056692: Sep  3 13:07:26.581 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 644
056693: Sep  3 13:07:26.581 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1043] removed.
056694: Sep  3 13:07:26.581 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
056695: Sep  3 13:07:26.581 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x8706B260 key=B802280C-511F11E5-918C93BD-3AE50455@itirt01
itirt01(config)#
056696: Sep  3 13:07:26.581 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
056697: Sep  3 13:07:26.581 PCTime: //1604/B74B0BC89187/SIP/Info/ccsip_qos_cleanup: Entry
056698: Sep  3 13:07:26.581 PCTime: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
056699: Sep  3 13:07:26.581 PCTime: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
056700: Sep  3 13:07:26.581 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
056701: Sep  3 13:07:26.585 PCTime: //1604/B74B0BC89187/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 8706B260
056702: Sep  3 13:07:26.585 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[1043]
056703: Sep  3 13:07:26.585 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 210
056704: Sep  3 13:07:26.585 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_SUBSCRIPTION_TERMINATED] received in State [SUBSCRIBE_STATE_ACTIVE]
056705: Sep  3 13:07:26.585 PCTime: //0/000000000000/SIP/Info/act_subscription_terminated: Resetting server EDB flag
056706: Sep  3 13:07:26.585 PCTime: //0/000000000000/SIP/Info/sipSPITerminateEvent: 1 Events still active on this Subscription Dialog
056707: Sep  3 13:07:26.585 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 210
056708: Sep  3 13:07:26.585 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_SUBSCRIPTION_TERMINATED] received in State [SUBSCRIBE_STATE_ACTIVE]
056709: Sep  3 13:07:26.585 PCTime: //0/000000000000/SIP/Info/act_subscription_terminated: Resetting Client EDB flag
056710: Sep  3 13:07:26.585 PCTime: //0/000000000000/SIP/Info/sipSPIFreeOneEDB: There are 1 EDBs on edbQ
056711: Sep  3 13:07:26.585 PCTime: //0/000000000000/SIP/Info/sipSPIFreeOneEDB: DeQ'd EDB(0x870AF5F8)
056712: Sep  3 13:07:26.585 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneEDB: EnQing EDB(0x870AF5F8) for reuse
056713: Sep  3 13:07:26.585 PCTime: //0/000000000000/SIP/Info/sipSPITerminateEvent: Freeing SCB(0x870ABADC), 0 active events present
056714: Sep  3 13:07:26.585 PCTime: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1044] removed.
056715: Sep  3 13:07:26.585 PCTime: //0/000000000000/SIP/Info/sipSPIRemoveSCBFromClientTable: Removing SCB(0x870ABADC) with Key(B802280C-511F11E5-918C93BD-3AE50455@itirt01F846DF0-104F) from Client Table
056716: Sep  3 13:07:26.585 PCTime: //0/000000000000/SIP/Info/sipSPIFreeOneSCB: EnQing SCB(0x870ABADC) for reuse
itirt01(config)#
056717: Sep  3 13:07:35.381 PCTime: %FW-3-SMTP_UNSUPPORTED_PARAMETER: Unsupported SMTP parameter (Data Size (> 20000000)) from initiator (192.168.1.41:50291)
itirt01(config)#
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.09.03 13:29:01 =~=~=~=~=~=~=~=~=~=~=~=
show run
Building configuration...
Current configuration : 53640 bytes
! Last configuration change at 13:13:45 PCTime Thu Sep 3 2015 by impact
! NVRAM config last updated at 13:13:40 PCTime Thu Sep 3 2015 by impact
version 12.4
parser config cache interface
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service internal
service compress-config
service sequence-numbers
hostname itirt01
boot-start-marker
boot system flash
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging message-counter syslog
enable secret 5 $1$3f37$X2fX2QMvs1/7Vps3auAn1/
aaa new-model
aaa authentication login default local
aaa authentication login vpn-client local
aaa authentication login iphone-vpn-client local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authentication enable default enable
aaa authentication ppp default local
aaa authorization exec default local
aaa authorization network vpn-client local
aaa authorization network iphone-vpn-client local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
clock timezone PCTime 10
crypto pki trustpoint TP
 enrollment selfsigned
 revocation-check crl
 rsakeypair TP
crypto pki certificate chain TP
 certificate self-signed 01
  308201A9 30820153 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  23312130 1F06092A 864886F7 0D010902 16126974 69727430 312E6974 692E636F
  6D2E6175 301E170D 31353037 31343031 35393439 5A170D32 30303130 31303030
  3030305A 30233121 301F0609 2A864886 F70D0109 02161269 74697274 30312E69
  74692E63 6F6D2E61 75305C30 0D06092A 864886F7 0D010101 0500034B 00304802
  4100D44F 0B7ADA52 C07768F7 288CEC1A A65C70CC B98A1927 4176A0EB 6E3FED54
  6826A431 36D3E0EE BCCE9D85 F4A12CAF E775C2A8 C2A2AD5B AF3E4008 E1EAB148
  1EF50203 010001A3 72307030 0F060355 1D130101 FF040530 030101FF 301D0603
  551D1104 16301482 12697469 72743031 2E697469 2E636F6D 2E617530 1F060355
  1D230418 30168014 310F52AA ECB3FD84 AF35D40A 670D8853 5C970703 301D0603
  551D0E04 16041431 0F52AAEC B3FD84AF 35D40A67 0D88535C 97070330 0D06092A
  864886F7 0D010104 05000341 00892BE7 49DD4CA7 7846E866 A96B7DAB 35DC3025
  C3954BE7 82528703 3D92525E BBEAC36E 545201A1 828F2427 927E0ECD EB3E8346
  88F466B4 8B75C17A BEA96841 72
  quit
dot11 syslog
no ip source-route
no ip gratuitous-arps
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.20
ip dhcp excluded-address 10.1.1.251 10.1.1.254
ip dhcp excluded-address 10.1.2.1 10.1.2.10
ip dhcp excluded-address 10.1.5.1 10.1.5.10
ip dhcp excluded-address 192.168.1.1 192.168.1.40
ip dhcp excluded-address 192.168.1.240 192.168.1.254
ip dhcp pool phone
   network 10.1.2.0 255.255.255.0
   default-router 10.1.2.1
   option 150 ip 10.1.0.1
ip dhcp pool user
   import all
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   netbios-name-server 192.168.1.2
   netbios-node-type h-node
   dns-server 192.168.1.2
   domain-name iti.local
ip dhcp pool student
   import all
   network 10.1.5.0 255.255.255.0
   default-router 10.1.5.1
   dns-server 203.12.160.35 203.12.160.36
ip dhcp pool Staff
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
no ip bootp server
ip domain lookup source-interface Loopback0
ip domain name dns1.tpgi.com.au
ip host trunk.engin.com.au 203.161.160.71
ip host voice.mibroadband.com.au 203.161.164.69
ip name-server 203.12.160.35
ip inspect name internet-fw-out cuseeme
ip inspect name internet-fw-out dns
ip inspect name internet-fw-out ftp
ip inspect name internet-fw-out h323
ip inspect name internet-fw-out https
ip inspect name internet-fw-out imap
ip inspect name internet-fw-out pop3
ip inspect name internet-fw-out netshow
ip inspect name internet-fw-out rcmd
ip inspect name internet-fw-out realaudio
ip inspect name internet-fw-out rtsp
ip inspect name internet-fw-out esmtp
ip inspect name internet-fw-out sqlnet
ip inspect name internet-fw-out streamworks
ip inspect name internet-fw-out tftp
ip inspect name internet-fw-out vdolive
ip inspect name internet-fw-out pptp
ip inspect name internet-fw-out icmp router-traffic
ip inspect name internet-fw-out tcp router-traffic
ip inspect name internet-fw-out udp router-traffic timeout 240
no ipv6 cef
ntp logging
ntp master 15
ntp update-calendar
stcapp ccm-group 1
stcapp
stcapp feature access-code
vpdn enable
vpdn-group internet
 description Internet PPPoE
 request-dialin
  protocol pppoe
trunk group pstn-out
 description All Analogue PSTN Interfaces
 hunt-scheme sequential
password encryption aes
voice call send-alert
voice rtp send-recv
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
 modem passthrough nse codec g711alaw
 sip
  registrar server expires max 3600 min 3600
  localhost dns:itirt01
  no update-callerid
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g729r8
 codec preference 3 g711ulaw
voice class codec 2
 codec preference 1 g711ulaw
voice class codec 3
 codec preference 2 g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
voice register global
 mode cme
 source-address 10.1.0.2 port 5060
 max-dn 128
 max-pool 32
 create profile sync 0052122621380335
voice logout-profile 1
voice user-profile 4
 user Nev password iti104
 number 104 type normal
voice user-profile 5
 user Lisa password iti105
 number 105 type normal
voice user-profile 6
 user BDM password iti106
 number 106 type normal
 number 171,172,173,174,175 type cw-overlay
voice user-profile 7
 user Sales1 password iti107
 number 107 type normal
voice user-profile 8
 user Sales2 password iti108
 number 108 type normal
voice user-profile 9
 user TrnMgr password iti109
 number 109 type normal
 number 161,162,163,164,165 type cw-overlay
voice user-profile 10
 user VETCod1 password iti110
 number 110 type normal
voice user-profile 11
 user VETCod2 password iti111
 number 111 type normal
voice user-profile 12
 user PTrn1 password iti112
 number 112 type normal
voice user-profile 13
 user PTrn2 password iti113
 number 113 type normal
voice user-profile 14
 user PTrn3 password iti114
 number 114 type normal
voice user-profile 15
 user PTrn4 password iti115
 number 115 type normal
voice user-profile 16
 user CTrn1 password iti116
 number 116 type normal
voice user-profile 17
 user CTrn2 password iti117
 number 117 type normal
voice user-profile 18
 user CTrn3 password iti118
 number 118 type normal
voice user-profile 19
 user CTrn4 password iti119
 number 119 type normal
voice user-profile 20
 user AOMgr password iti120
 number 120 type normal
 number 181,182,183,184,185 type cw-overlay
 number 141,142,143,144,145 type cw-overlay
voice user-profile 21
 user Adm1 password iti121
 number 121 type normal
voice user-profile 22
 user Adm2 password iti122
 number 122 type normal
voice user-profile 23
 user Adm3 password iti123
 number 123 type normal
voice user-profile 24
 user Adm4 password iti124
 number 124 type normal
voice user-profile 30
 user support password support
 number 130,131 type normal
voice translation-rule 10
 rule 1 /^0/ //
voice translation-rule 20
 rule 1 // /00/
voice translation-rule 30
 rule 1 /0280903546/ /196/
 rule 2 /0298069822/ /198/
voice translation-rule 40
 rule 1 /131/ /61280903546/
 rule 2 /^.*/ /0298069822/
voice translation-rule 50
 rule 1 // /0/
voice translation-rule 60
 rule 1 /^0\(.*\)/ /\1/
voice translation-rule 70
 rule 1 /^0\(.*\)/ /3\1/
voice translation-rule 80
 rule 1 /^3/ //
voice translation-rule 90
 rule 15 /^.*/ /61298069833/
voice translation-profile fax-eftpos-in
 translate called 70
voice translation-profile fax-eftpos-out
 translate calling 90
 translate called 80
voice translation-profile pstn-in
 translate calling 20
voice translation-profile pstn-out
 translate called 10
voice translation-profile sip-trunk-in
 translate calling 50
 translate called 30
voice translation-profile sip-trunk-out
 translate calling 40
 translate called 10
 translate redirect-target 60
 translate redirect-called 60
voice-card 0
 dsp services dspfarm
application
 service aa flash:app-b-acd-aa-3.0.0.1.tcl
  param number-of-hunt-grps 1
  paramspace english index 1
  param drop-through-option 1
  param handoff-string aa
  paramspace english language en
  param max-time-vm-retry 2
  param aa-pilot 197
  paramspace english location flash:
  param second-greeting-time 30
  param call-retry-timer 15
  param max-time-call-retry 180
  param voice-mail 200
  param service-name queue
 service queue flash:app-b-acd-3.0.0.1.tcl
  param queue-len 10
  param aa-hunt1 100
  param queue-manager-debugs 1
file verify auto
spanning-tree portfast bpduguard
spanning-tree vlan 1 priority 0
spanning-tree vlan 2 priority 0
spanning-tree vlan 3 priority 0
spanning-tree vlan 5 priority 0
vtp domain iti
vtp mode transparent
vtp version 2
username itiiphonevpnuser privilege 0 secret 5 $1$Zl..$XXXXXXXXXXXXXX
username itivpnuser99 privilege 0 secret 5 $1$VRHfXXXXXXXXXXXXXXXXX
username impact privilege 15 password 7 095C4FXXXXXXXXXXXXXXXXXXXX
username itivpnuser privilege 0 password 7 0XXXXXXXXXXXXXXXXXXXXXXXX
username itadmin privilege 15 password 7 01XXXXXXXXXXXXXXXXXXXXXXXXXX
username neville privilege 15 secret 5 $1$1XXXXXXXXXXXXXXXXXXXXXXXXXXXX
username lisa privilege 15 secret 5 $1$475h$4QKXXXXXXXXXXXXXXXXXXXXX
username tandry password 7 06421XXXXXXXXXXXXXXXXXXXXXX
username amelia password 7 041F0A0BXXXXXXXXXXXXXXXXXXXXXXXX
crypto logging session
crypto isakmp policy 10
 encr aes 256
 authentication pre-share
 group 5
 lifetime 3600
crypto isakmp policy 20
 encr aes 256
 group 2
crypto isakmp keepalive 30 5 periodic
crypto isakmp nat keepalive 30
crypto isakmp xauth timeout 30
crypto isakmp client configuration group ITI
 key 6 S^]O\b^`KA^XaK\FESIJhYfGBfdQeeNdI
 dns 192.168.1.2
 domain iti.local
 pool SDM_POOL_2
 acl 101
 netmask 255.255.255.0
crypto isakmp profile ciscocp-ike-profile-1
   match identity group ITI
   client authentication list ciscocp_vpn_xauth_ml_1
   isakmp authorization list ciscocp_vpn_group_ml_1
   client configuration address initiate
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set vpn-client esp-aes 256 esp-sha-hmac
crypto ipsec transform-set iphone-vpn-client esp-aes 256 esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec df-bit clear
crypto ipsec profile CiscoCP_Profile1
 set transform-set ESP-3DES-SHA
 set isakmp-profile ciscocp-ike-profile-1
crypto call admission limit ike sa 50
archive
 log config
  logging enable
  logging size 500
  hidekeys
vlan 2
 name Cisco-Voice
vlan 3
 name Staff
vlan 5
 name student
ip telnet source-interface Loopback0
ip telnet hidden hostnames
ip telnet hidden addresses
no ip ftp passive
ip ftp source-interface Loopback0
ip tftp source-interface Loopback0
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh source-interface Loopback0
ip ssh rsa keypair-name itirt01.iti.com.au
ip ssh logging events
ip ssh version 2
ip scp server enable
class-map match-any iptel-signalling-out
 match access-group name iptel-signalling-out
class-map match-all management-out
 match access-group name management-out
class-map match-all iptel-voice-out
 match protocol rtp audio
 match ip dscp ef
policy-map internet-qos-out
 description QoS policy map for Internet
 class iptel-voice-out
    priority percent 30
  set ip dscp ef
 class iptel-signalling-out
    bandwidth remaining percent 10
  set ip dscp cs3
 class management-out
  set ip dscp af31
 class class-default
    fair-queue
     random-detect
  set ip precedence 0
bba-group pppoe global
interface Loopback0
 description Router ID
 ip address 10.1.0.1 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
 ip virtual-reassembly
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.1.0.1
interface FastEthernet0/0
 description Internet Access
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
 no cdp enable
interface Integrated-Service-Engine0/0
 description CUE iticue01
 ip unnumbered Loopback0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
 service-module ip address 10.1.0.2 255.255.255.252
 service-module ip default-gateway 10.1.0.1
interface FastEthernet0/1/0
 description WiFi itiap01 Fa0
 switchport mode trunk
 storm-control broadcast level 20.00
interface FastEthernet0/1/1
 description WiFi itiap02 Fa0
interface FastEthernet0/1/2
 description WiFi itiap03 Fa0
interface FastEthernet0/1/3
 description phone
 switchport voice vlan 2
 macro description cisco-wireless
interface FastEthernet0/1/4
 description phone
 switchport access vlan 3
 macro description cisco-phone
interface FastEthernet0/1/5
 description phone
interface FastEthernet0/1/6
 description phone
interface FastEthernet0/1/7
 description phone
interface FastEthernet0/1/8
 description Switch itisw01 Fa0/1
 macro description cisco-switch
interface Virtual-Template1 type tunnel
 ip unnumbered Vlan3
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile CiscoCP_Profile1
interface Vlan1
 description user
 ip address 10.1.1.1 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
interface Vlan2
 description phone
 ip address 10.1.2.1 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
interface Vlan3
 description Staff
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
interface Vlan5
 description Student
 ip address 10.1.5.1 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
interface Dialer1
 description Internet Dialer for PPPoE
 mtu 1492
 bandwidth 2000
 ip address negotiated
 ip access-group internet-filter-in in
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 ip inspect internet-fw-out out
 encapsulation ppp
 ip tcp adjust-mss 1424
 load-interval 30
 dialer pool 1
 dialer-group 1
 no cdp enable
 ppp chap hostname imp146714@pig.tpg.com.au
 ppp chap password 7 11584D5340435F05093A
 ppp pap sent-username imp146714@pig.tpg.com.au password 7 15435F5A537B7F2D2523
 service-policy output internet-qos-out
ip local pool vpn-client 10.1.4.11 10.1.4.254
ip local pool iphone-vpn-client 10.1.6.11 10.1.6.254
ip local pool SDM_POOL_1 192.168.1.30 192.168.1.50
ip local pool SDM_POOL_2 192.168.5.10 192.168.5.50
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 10.1.0.2 255.255.255.255 Integrated-Service-Engine0/0
ip http server
ip http access-class 80
ip http authentication local
no ip http secure-server
ip http path flash:/gui
ip nat inside source list internal-to-internet interface Dialer1 overload
ip nat inside source static tcp 10.1.1.19 443 interface Dialer1 443
ip nat inside source static tcp 192.168.1.2 25 interface Dialer1 25
ip nat inside source static tcp 192.168.1.3 3389 interface Dialer1 3389
ip nat inside source static tcp 10.1.0.1 5060 interface Dialer1 5060
ip nat inside source static tcp 10.1.0.1 5061 interface Dialer1 5061
ip nat inside source static udp 10.1.0.1 5060 interface Dialer1 5060
ip nat inside source static udp 10.1.0.1 5061 interface Dialer1 5061
ip access-list extended internal-to-internet
 deny   ip 10.1.0.0 0.0.255.255 10.1.0.0 0.0.255.255
 permit ip 10.1.0.0 0.0.255.255 any
 permit ip 192.168.0.0 0.0.255.255 any
ip access-list extended internet-filter-in
 deny   ip 192.168.0.0 0.0.255.255 any
 deny   ip 172.16.0.0 0.15.255.255 any
 deny   ip 10.0.0.0 0.255.255.255 any
 deny   ip 169.254.0.0 0.0.255.255 any
 deny   ip 192.0.2.0 0.0.0.255 any
 deny   ip host 255.255.255.255 any
 deny   ip host 0.0.0.0 any
 permit icmp any any echo
 permit icmp any any echo-reply
 permit icmp any any unreachable
 permit icmp any any ttl-exceeded
 permit tcp any any eq smtp
 permit tcp any any eq 443
 permit tcp any any eq 7443
 permit udp any any eq isakmp
 permit udp any any eq non500-isakmp
 permit esp any any
 permit udp any host 10.1.0.1 eq 5060
 permit tcp any host 10.1.0.1 eq 5060
 permit udp any host 10.1.0.1 eq 5061
 permit tcp any host 10.1.0.1 eq 5061
 permit udp any any range 16384 32767
 deny   ip any any log
ip access-list extended iptel-signalling-out
 remark SIP control traffic
 permit udp any host 110.93.18.134 eq 5060
 permit udp any eq 5060 host 110.93.18.134
ip access-list extended management-out
 remark Management traffic
 permit tcp any any eq 22
 permit tcp any eq 22 any
ip access-list extended vpn-client-split-tunnel
 remark CCP_ACL Category=16
 permit ip 10.1.0.0 0.0.255.255 10.1.0.0 0.0.255.255
 permit ip 10.1.0.0 0.0.255.255 192.168.0.0 0.0.255.255
 permit ip 192.168.0.0 0.0.255.255 10.1.0.0 0.0.255.255
 permit ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
ip sla responder
logging history size 500
logging history informational
logging trap debugging
logging origin-id hostname
logging source-interface Loopback0
access-list 22 remark Permitted SSH Access
access-list 22 permit any log
access-list 24 remark Permitted Outgoing Access
access-list 24 permit any log
access-list 25 remark Denied Outgoing Access
access-list 25 deny   any log
access-list 80 remark Permitted HTTP Access
access-list 80 permit any log
access-list 100 remark CCP_ACL Category=4
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 remark CCP_ACL Category=4
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 10.1.1.0 0.0.0.255 any
access-list 102 remark CCP_ACL Category=4
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list compiled reuse
dialer-list 1 protocol ip permit
tftp-server flash:Desktops/320x212x12/CampusNight.png
tftp-server flash:Desktops/320x212x12/CiscoFountain.png
tftp-server flash:Desktops/320x212x12/MorroRock.png
tftp-server flash:Desktops/320x212x12/NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/TN-CampusNight.png
tftp-server flash:Desktops/320x212x12/TN-CiscoFountain.png
tftp-server flash:Desktops/320x212x12/TN-Fountain.png
tftp-server flash:Desktops/320x212x12/TN-MorroRock.png
tftp-server flash:Desktops/320x212x12/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/Fountain.png
tftp-server flash:Desktops/320x212x12/CiscoLogo.png
tftp-server flash:Desktops/320x212x12/TN-CiscoLogo.png
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:gui/admin_user.html
tftp-server flash:gui/admin_user.js
tftp-server flash:gui/CiscoLogo.gif
tftp-server flash:gui/Delete.gif
tftp-server flash:gui/dom.js
tftp-server flash:gui/downarrow.gif
tftp-server flash:gui/ephone_admin.html
tftp-server flash:gui/logohome.gif
tftp-server flash:gui/normal_user.html
tftp-server flash:gui/normal_user.js
tftp-server flash:gui/Plus.gif
tftp-server flash:gui/sxiconad.gif
tftp-server flash:gui/Tab.gif
tftp-server flash:gui/telephony_service.html
tftp-server flash:gui/uparrow.gif
tftp-server flash:gui/xml-test.html
tftp-server flash:gui/xml.template
tftp-server flash:ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:ringtones/Bass.raw alias Bass.raw
tftp-server flash:ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:ringtones/Chime.raw alias Chime.raw
tftp-server flash:ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:ringtones/Pop.raw alias Pop.raw
tftp-server flash:ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:ringtones/RingList.xml alias RingList.xml
tftp-server flash:ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:APPS-1.2.1.SBN
tftp-server flash:SYS-1.2.1.SBN
tftp-server flash:GUI-1.2.1.SBN
tftp-server flash:CP7921G-1.2.1.LOADS
tftp-server flash:TNUX-1.2.1.SBN
tftp-server flash:TNUXR-1.2.1.SBN
tftp-server flash:WLAN-1.2.1.SBN
tftp-server flash:apps37sccp.1-2-1-0.bin
tftp-server flash:APPSH-1.3.1.SBN
tftp-server flash:GUIH-1.3.1.SBN
tftp-server flash:CP7925G-1.3.1.LOADS
tftp-server flash:SYSH-1.3.1.SBN
tftp-server flash:TNUXH-1.3.1.SBN
tftp-server flash:WLANH-1.3.1.SBN
tftp-server flash:S00105000300.sbn
tftp-server flash:P00308000500.bin
tftp-server flash:P00308000500.loads
tftp-server flash:P00308000500.sb2
tftp-server flash:P00308000500.sbn
control-plane
call threshold global cpu-avg low 68 high 75
call threshold global total-mem low 75 high 85
call threshold global total-calls low 8 high 10
voice-port 0/0/0
 input gain -6
 output attenuation -6
 echo-cancel coverage 32
 no vad
 cptone AU
 timeouts interdigit 2
 timeouts call-disconnect 3
 timeouts ringing infinity
 timeouts wait-release 3
 description Not in Use
voice-port 0/0/1
 input gain -6
 no vad
 cptone AU
voice-port 0/0/2
 input gain -6
 no vad
 cptone AU
 description EFTPOS - 113
voice-port 0/0/3
 input gain -6
 no vad
 cptone AU
 description Fax Machine - 114
voice-port 0/1/0
 trunk-group pstn-out 1
 supervisory disconnect dualtone mid-call
 input gain -3
 no vad
 cptone AU
 timeouts interdigit 3
 connection plar opx 198
 impedance complex1
 description Voice PSTN Service - 61xxxxxxxxx
 caller-id enable
voice-port 0/1/1
 trunk-group pstn-out 2
 input gain -3
 no vad
 cptone AU
 impedance complex1
 caller-id enable
voice-port 0/1/2
 trunk-group pstn-out 3
 input gain -3
 no vad
 cptone AU
 impedance complex1
 description EFTPOS PSTN Service - 61xxxxxxxxx
 caller-id enable
voice-port 0/1/3
 trunk-group pstn-out 4
 input gain -3
 no vad
 cptone AU
 impedance complex1
 description Fax PSTN Service - 61xxxxxxxxx
 caller-id enable
voice-port 0/3/0
voice-port 0/3/1
 input gain -3
 no vad
 cptone AU
 impedance complex1
 caller-id enable
voice-port 0/3/2
 input gain -3
 no vad
 cptone AU
 impedance complex1
 caller-id enable
voice-port 0/3/3
 input gain -3
 no vad
 cptone AU
 impedance complex1
 caller-id enable
voice-port 0/4/0
 auto-cut-through
 signal immediate
 input gain auto-control -15
 description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.0.1 identifier 1 version 7.0
sccp
sccp ccm group 2
 description sccp-ccm transcoding group
 bind interface Loopback0
 associate ccm 1 priority 1
 associate profile 2 register itirt01t
sccp ccm group 1
 description sccp-ccm FXS group
dspfarm profile 2 transcode
 description dspf-transcoding dspfarm profile
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729r8
 codec g729br8
 maximum sessions 6
 associate application SCCP
dial-peer cor custom
 name emergency
 name local
 name mobile
 name std
 name idd
dial-peer cor list pots-emergency-out
 member emergency
dial-peer cor list pots-local-out
 member local
dial-peer cor list pots-std-out
 member std
dial-peer cor list pots-mobile-out
 member mobile
dial-peer cor list pots-idd-out
 member idd
dial-peer cor list dn-emergency-in
 member emergency
dial-peer cor list dn-local-in
 member emergency
 member local
dial-peer cor list dn-std-in
 member emergency
 member local
 member std
dial-peer cor list dn-std-and-mobile-in
 member emergency
 member local
 member mobile
 member std
dial-peer cor list dn-idd-out
 member emergency
 member local
 member mobile
 member std
 member idd
dial-peer cor list voip-emergency-out
 member emergency
dial-peer cor list voip-local-out
 member local
dial-peer cor list voip-std-out
 member std
dial-peer cor list voip-mobile-out
 member mobile
dial-peer cor list voip-idd-out
 member idd
dial-peer voice 193 pots
 description Music on Hold Port
 destination-pattern ABC
 port 0/4/0
 no sip-register
dial-peer voice 190 voip
 description CUE Prompt Management Number
 destination-pattern 190
 monitor probe icmp-ping
 b2bua
 voice-class codec 2
 no voice-class sip outbound-proxy
 session protocol sipv2
 session target ipv4:10.1.0.2
 dtmf-relay sip-notify
 no vad
dial-peer voice 197 voip
 description Reception Queue
 service aa
 destination-pattern 197
 voice-class codec 2
 voice-class h323 1
 session target ipv4:10.1.0.1
 incoming called-number 197
 dtmf-relay h245-alphanumeric
 no vad
dial-peer voice 199 voip
 description CUE Voice Mail Pilot Number
 destination-pattern 199
 b2bua
 voice-class codec 2
 no vad
dial-peer voice 1000 voip
 description Outgoing Call to SIP Trunk
 translation-profile outgoing sip-trunk-out
 max-conn 5
 destination-pattern 0T
 voice-class codec 1
 voice-class sip dtmf-relay force rtp-nte
 session target sip-server
 dtmf-relay rtp-nte
 no vad
dial-peer voice 1001 pots
 trunkgroup pstn-out
 description Voice PSTN Trunk Group
 translation-profile outgoing pstn-out
 preference 1
 forward-digits all
 no sip-register
dial-peer voice 3000 voip
 description Outgoing Fax & EFTPOS Call to SIP Trunk
 translation-profile outgoing fax-eftpos-out
 destination-pattern 3T
 voice-class codec 3
 dtmf-relay rtp-nte
 fax rate 9600
 no vad
dial-peer voice 3001 pots
 description pots-PSTN Serivce - Fax & EFTPOS Call
 preference 1
 clid restrict
 port 0/1/3
 forward-digits all
 no sip-register
dial-peer voice 196 voip
 description CUE Salon AA Number
 destination-pattern 196
 b2bua
 voice-class codec 2
 no vad
dial-peer voice 2000 voip
 description Incoming Voice Call from SIP Trunk
 translation-profile incoming sip-trunk-in
 voice-class codec 1
 incoming called-number .%
 dtmf-relay rtp-nte
 fax rate 9600
 no vad
dial-peer voice 198 voip
 description CUE ITI AA Number
 destination-pattern 198
 voice-class codec 2
 voice-class sip outbound-proxy ipv4:10.1.0.2
no dial-peer outbound status-check pots
gateway
 media-inactivity-criteria all
 timer receive-rtcp 30
 timer receive-rtp 180
sip-ua
 credentials username 0298069822 password 7 072439157A083C3002 realm voice.mibroadband.com.au
 authentication username 0298069822 password 7 01381E5D6F0A233A34
 no remote-party-id
 retry invite 2
 retry register 10
 timers connect 100
 registrar dns:voice.mibroadband.com.au expires 3600
 sip-server dns:trunk.engin.com.au
 connection-reuse
 host-registrar
 g729-annexb override
telephony-service
 sdspfarm units 5
 sdspfarm transcode sessions 8
 sdspfarm tag 2 itirt01t
 video
 no auto-reg-ephone
 authentication credential itadmin XXXXXXXX
 fxo hook-flash
 max-ephones 32
 max-dn 128
 ip source-address 10.1.0.1 port 2000
 max-redirect 20
 calling-number initiator
 service phone videoCapability 1
 service dnis overlay
 service dnis dir-lookup
 timeouts busy 5
 timeouts ringing 90
 system message Impact Training Institute
 url services http://10.1.0.2/voiceview/common/login.do
 load 7961 SCCP41.8-4-2S
 load 7970 SCCP70.8-4-2S
 time-zone 47
 date-format dd-mm-yy
 voicemail 199
 max-conferences 8 gain -6
 call-forward pattern .T
 call-forward system redirecting-expanded
 hunt-group logout HLog
 moh music-on-hold.au
 multicast moh 239.1.1.1 port 16384 route 10.1.2.1
 web admin system name impact secret 5 $1$uWF7$4hM22myBITGCUJXXXXXXXXXXXXXX
 dn-webedit
 time-webedit
 transfer-system full-consult dss
 transfer-pattern 1..
 secondary-dialtone 0
 login timeout 120 clear 01:00
 directory entry 190 190 name AvT Administration
 directory entry 197 197 name Reception Queue
 directory entry 199 199 name Voice Mail
 fac custom callfwd all **1
 fac custom callfwd cancel **2
 fac custom pickup local **3
 fac custom pickup group **4
 fac custom pickup direct **5
 fac custom park **6
 fac custom dnd **7
 fac custom redial **8
 fac custom voicemail **9
 fac custom ephone-hunt join *3
 fac custom ephone-hunt cancel #3
 fac custom ephone-hunt hlog *4
 fac custom ephone-hunt hlog-phone *5
 fac custom trnsfvm *6
 create cnf-files version-stamp 7960 Jun 18 2015 16:27:38
ephone-dn-template  1
 call-forward busy 199
 call-forward noan 199 timeout 20
 hold-alert 30 originator
 pickup-group 1
ephone-dn-template  2
 pickup-group 2
ephone-dn-template  3
 pickup-group 3
ephone-dn-template  4
 pickup-group 4
ephone-dn-template  5
 pickup-group 5
ephone-dn-template  6
 call-forward all 100
 pickup-group 1
ephone-dn-template  14
ephone-dn-template  15
 pickup-group 1
ephone-template  1
 conference drop-mode local
 softkeys hold  Resume Newcall Join Select
 softkeys idle  Redial Newcall Gpickup Cfwdall ConfList Join RmLstC Dnd
 softkeys seized  Redial Endcall Cfwdall Pickup Gpickup Callback Meetme
 softkeys connected  Endcall Hold Trnsfer Park Confrn ConfList Join Select RmLstC
 softkeys ringing  Answer Dnd
ephone-template  2
ephone-template  3
ephone-template  4
ephone-template  5
ephone-template  15
ephone-dn  1  dual-line
 number 101 no-reg primary
 label Front Desk 101
 description Front Desk 1
 name Front Desk 1
ephone-dn  2  dual-line
 number 102 no-reg primary
 label Front Desk 102
 description Front Desk 2
 name Front Desk 2
ephone-dn  3  dual-line
 number 103 no-reg primary
 label Jemma 103
 description Jemma
 name Jemma
ephone-dn  4  dual-line
 number 104 no-reg primary
 label Neville 104
 description Neville
 name Neville
ephone-dn  5  dual-line
 number 105 no-reg primary
 label Lisa 105
 description Lisa
 name Lisa
ephone-dn  6  dual-line
 number 106 no-reg primary
 label BDM 106
 description BDM
 name BDM
ephone-dn  7  dual-line
 number 107 no-reg primary
 label Sales01 107
 description Sales01
 name Sales01
ephone-dn  8  dual-line
 number 108 no-reg primary
 label Sales02 108
 description Sales02
 name Sales02
ephone-dn  9  dual-line
 number 109 no-reg primary
 label TrainingMgr 109
 description TrainingMgr
 name TrainingMgr
ephone-dn  10  dual-line
 number 110 no-reg primary
 label VETCoord01 110
 description VETCoord01
 name VETCoord01
ephone-dn  11  dual-line
 number 111 no-reg primary
 label VETCoord02 111
 description VETCoord02
 name VETCoord02
ephone-dn  12  dual-line
 number 112 no-reg primary
 label PermTrainer01 112
 description PermTrainer01
 name PermTrainer01
ephone-dn  13  dual-line
 number 113 no-reg primary
 label PermTrainer02 113
 description PermTrainer02
 name PermTrainer02
ephone-dn  14  dual-line
 number 114 no-reg primary
 label PermTrainer03 114
 description PermTrainer03
 name PermTrainer03
ephone-dn  15  dual-line
 number 115 no-reg primary
 label PermTrainer04 115
 description PermTrainer04
 name PermTrainer04
ephone-dn  16  dual-line
 number 116 no-reg primary
 label ConTrainer01 116
 description ConTrainer01
 name ConTrainer01
ephone-dn  17  dual-line
 number 117 no-reg primary
 label ConTrainer02 117
 description ConTrainer02
 name ConTrainer02
ephone-dn  18  dual-line
 number 118 no-reg primary
 label ConTrainer03 118
 description ConTrainer03
 name ConTrainer03
ephone-dn  19  dual-line
 number 119 no-reg primary
 label ConTrainer04 119
 description ConTrainer04
 name ConTrainer04
ephone-dn  20  dual-line
 number 120 no-reg primary
 label AdmOpsMgr 120
 description AdmOpsMgr
 name AdmOpsMgr
ephone-dn  21  dual-line
 number 121 no-reg primary
 label Admin01 121
 description Admin01
 name Admin01
ephone-dn  22  dual-line
 number 122 no-reg primary
 label Admin02 122
 description Admin02
 name Admin02
ephone-dn  23  dual-line
 number 123 no-reg primary
 label Admin03 123
 description Admin03
 name Admin03
ephone-dn  24  dual-line
 number 124 no-reg primary
 label Admin04 124
 description Admin04
 name Admin04
ephone-dn  25  dual-line
 number 125 no-reg primary
 label Front Desk 125
 description Front Desk 3
 name Front Desk 3
ephone-dn  26  dual-line
 number 126 no-reg primary
 label Board Room 126
 description Board Room
 name Board Room
ephone-dn  27  dual-line
 number 127 no-reg primary
 label Spare 127
 description Spare
 name Spare
ephone-dn  28  dual-line
 number 128 no-reg primary
 label Spare 128
 description Spare
 name Spare
ephone-dn  29  dual-line
 number 129 no-reg primary
 label Spare 129
 description Spare
 name Spare
ephone-dn  30  dual-line
 number 130 no-reg primary
 label Support 130
 description Support
 name Support
ephone-dn  31  dual-line
 number 131 no-reg primary
 label Salon 131
 description Salon
 name Salon
ephone-dn  32  dual-line
 number 132 no-reg primary
 label Salon VM 132
 description Salon VM
 name Salon VM
ephone-dn  41  dual-line
 number 141 no-reg primary
 label Reception 100
 description Reception DN 1 of 5
 name Reception
 huntstop channel
ephone-dn  42  dual-line
 number 142 no-reg primary
 label Reception 100
 description Reception DN 2 of 5
 name Reception
 huntstop channel
ephone-dn  43  dual-line
 number 143 no-reg primary
 label Reception 100
 description Reception DN 3 of 5
 name Reception
 huntstop channel
ephone-dn  44  dual-line
 number 144 no-reg primary
 label Reception 100
 description Reception DN 4 of 5
 name Reception
 huntstop channel
ephone-dn  45  dual-line
 number 145 no-reg primary
 label Reception 100
 description Reception DN 5 of 5
 name Reception
 huntstop channel
ephone-dn  46
 number *01 no-reg primary
 park-slot timeout 60 limit 5
 label Park Slot 1
 description Call Park slot 1
 name Park Slot 1
ephone-dn  47
 number *02 no-reg primary
 label Park Slot 2
 description Call Park slot 2
 name Park Slot 2
ephone-dn  48
 number *03 no-reg primary
 label Park Slot 3
 description Call Park slot 3
 name Park Slot 3
ephone-dn  49
 number 200 no-reg primary
 label Reception VM 200
 description Reception VoiceMail
 name Reception VoiceMail
ephone-dn  50
 number A150... no-reg primary
 mwi off
ephone-dn  51
 number A151... no-reg primary
 mwi on
ephone-dn  52
 number BCD no-reg primary
 description MoH
 moh ip 239.1.1.2 port 16384 out-call ABC
ephone-dn  56
 number 0298069822
 description ITI SIP Trunk DID number
ephone-dn  61  dual-line
 number 161 no-reg primary
 label Training 160
 description Training DN 1 of 5
 name Training
 huntstop channel
ephone-dn  62  dual-line
 number 162 no-reg primary
 label Training 160
 description Training DN 2 of 5
 name Training
 huntstop channel
ephone-dn  63  dual-line
 number 163 no-reg primary
 label Training 160
 description Training DN 3 of 5
 name Training
 huntstop channel
ephone-dn  64  dual-line
 number 164 no-reg primary
 label Training 160
 description Training DN 4 of 5
 name Training
 huntstop channel
ephone-dn  65  dual-line
 number 165 no-reg primary
 label Training 160
 description Training DN 5 of 5
 name Training
 huntstop channel
ephone-dn  69
 number 260 no-reg primary
 label Training VM 260
 description Training VoiceMail
 name Training VoiceMail
ephone-dn  71  dual-line
 number 171 no-reg primary
 label Sales 170
 description Sales DN 1 of 5
 name Sales
 huntstop channel
ephone-dn  72  dual-line
 number 172 no-reg primary
 label Sales 170
 description Sales DN 2 of 5
 name Sales
 huntstop channel
ephone-dn  73  dual-line
 number 173 no-reg primary
 label Sales 170
 description Sales DN 3 of 5
 name Sales
 huntstop channel
ephone-dn  74  dual-line
 number 174 no-reg primary
 label Sales 160
 description Sales DN 4 of 5
 name Sales
 huntstop channel
ephone-dn  75  dual-line
 number 175 no-reg primary
 label Sales 170
 description Sales DN 5 of 5
 name Sales
 huntstop channel
ephone-dn  79
 number 270 no-reg primary
 label Sales VM 270
 description Sales VoiceMail
 name Sales VoiceMail
ephone-dn  81  dual-line
 number 181 no-reg primary
 label Admin 180
 description Admin DN 1 of 5
 name Admin
 huntstop channel
ephone-dn  82  dual-line
 number 182 no-reg primary
 label Admin 180
 description Admin DN 2 of 5
 name Admin
 huntstop channel
ephone-dn  83  dual-line
 number 183 no-reg primary
 label Admin 180
 description Admin DN 3 of 5
 name Admin
 huntstop channel
ephone-dn  84  dual-line
 number 184 no-reg primary
 label Admin 180
 description Admin DN 4 of 5
 name Admin
 huntstop channel
ephone-dn  85  dual-line
 number 185 no-reg primary
 label Admin 180
 description Admin DN 5 of 5
 name Admin
 huntstop channel
ephone-dn  89
 number 280 no-reg primary
 label Admin VM 280
 description Admin VoiceMail
 name Admin VoiceMail
ephone-dn  101
ephone  1
 device-security-mode none
 video
 mac-address 0017.95B1.3470
 ephone-template 1
 username "FrontDesk1" password null
 type 7961
 button  1:1 2c41,42,43,44,45 3c61,62,63,64,65 4c71,72,73,74,75
 button  5c81,82,83,84,85
ephone  4
 video
 mac-address 001E.F728.9B6B
 ephone-template 1
 type 7971
 logout-profile 1
ephone  5
 video
 mac-address 001F.6C80.8D10
 ephone-template 1
 type 7971
 logout-profile 1
ephone  6
 video
 mac-address 0016.46CB.58F4
 ephone-template 1
 type 7961
 logout-profile 1
ephone  7
 video
 mac-address 0017.95BD.C9B0
 ephone-template 1
 username "FrontDesk3" password null
 type 7961
 button  1:25 2c41,42,43,44,45 3c61,62,63,64,65 4c71,72,73,74,75
ephone  8
 video
 mac-address 0018.18D7.3FE9
 ephone-template 1
 type 7961
 logout-profile 1
ephone  9
 video
 mac-address 0017.95CF.027D
 ephone-template 1
 username "FrontDesk2" password null
 type 7961
 button  1:2 2c41,42,43,44,45 3c61,62,63,64,65 4c71,72,73,74,75
ephone  10
 video
 mac-address 0017.95CF.0199
 ephone-template 1
 type 7961
 logout-profile 1
ephone  11
 video
 mac-address 0017.592E.FE15
 ephone-template 1
 type 7961
 logout-profile 1
ephone  12
 video
 mac-address 0017.E033.054C
 ephone-template 1
 username "Jemma" password null
 type 7961
 button  1:3 2c41,42,43,44,45 3c61,62,63,64,65 4c71,72,73,74,75
ephone  13
 video
 mac-address 0018.1803.0D79
 ephone-template 1
 type 7961
 logout-profile 1
ephone  14
 video
 mac-address 0017.95B1.3912
 ephone-template 1
 type 7961
 logout-profile 1
ephone  15
 video
 mac-address 0017.95B1.339D
 ephone-template 1
 type 7961
 logout-profile 1
ephone  16
 video
 mac-address 0017.E015.28F7
 ephone-template 1
 type 7961
 logout-profile 1
ephone  17
 video
ephone  18
 video
 mac-address 0021.9BD4.7EF8
 ephone-template 1
 type CIPC
 logout-profile 1
ephone  19
 video
 mac-address 0026.2234.34FD
 ephone-template 1
 type CIPC
 logout-profile 1
ephone  20
 video
 mac-address 0016.46E0.6EF7
 ephone-template 1
 type 7961
 logout-profile 1
ephone  21
 video
 mac-address 0017.E089.7B03
 ephone-template 1
 type 7961
 logout-profile 1
ephone  22
 video
 mac-address 001A.A1A8.0DD4
 ephone-template 1
 type 7961
 logout-profile 1
ephone  26
 video
 mac-address 0004.F2E3.6D36
 ephone-template 1
 type 7936
 button  1:26
ephone  30
 video
 mac-address 0013.E835.1201
 ephone-template 1
 type CIPC
 logout-profile 1
ephone  31
 video
 mac-address 001A.A193.DE4F
 ephone-template 1
 username "Salon" password null
 type 7961
 button  1:31
ephone  32
 video
 mac-address 7071.BC00.5D69
 ephone-template 1
 type CIPC
 logout-profile 1
ephone-hunt 60 sequential
 pilot 160
 list 161, 162, 163, 164, 165
 final 199
 timeout 10, 5, 5, 5, 5
 no-reg pilot
 statistics collect
 description Training hunt group
ephone-hunt 70 sequential
 pilot 170
 list 171, 172, 173, 174, 175
 final 199
 no-reg pilot
 statistics collect
 description Sales hunt group
ephone-hunt 80 sequential
 pilot 180
 list 181, 182, 183, 184, 185
 final 199
 no-reg pilot
 statistics collect
 description Admin hunt group
ephone-hunt 100 sequential
 pilot 100
 list 141, 142, 143, 144, 145
 no-reg pilot
 statistics collect
 description Reception hunt group
banner login ^C
* Access to this computer system is limited to authorised users only. *
* Unauthorised users may be subject to prosecution under the Crimes   *
*                       Act or State legislation                      *
* Please note, ALL CUSTOMER DETAILS are confidential and must         *
*                         not be disclosed.                           *
^C
banner motd ^C
***************>>>   Authorised Users Only   <<<****************
* The information on this device and network is confidential   *
* and is protected by intellectual property laws.  You must be *
* assigned an account on this system to access information and *
* are  only allowed  to access  information  as defined by the *
*                     Network Administrator.                   *
**********>>>   Your activities will be monitored   <<<*********
*                Unauthorised Access Prohibited                *
*  Unauthorised  access of the network may result in  criminal *
*  and civil consequences and will be prosecuted to the extent *
*                       permitted by law.                      *
^C
line con 0
 access-class 24 out
 exec-timeout 20 0
 privilege level 0
 no modem enable
 transport output telnet ssh
 stopbits 1
line aux 0
 access-class 22 in
 access-class 25 out
 exec-timeout 20 0
 privilege level 0
 session-limit 1
 transport preferred telnet
 transport input telnet
 transport output none
 stopbits 1
line 2
 access-class 22 in
 access-class 25 out
 exec-timeout 20 0
 privilege level 0
 session-limit 1
 no activation-character
 no exec
 stopbits 1
line vty 0 4
 access-class 22 in
 access-class 24 out
 exec-timeout 20 0
 session-limit 7
 logging synchronous
 transport preferred ssh
 transport input ssh
line vty 5 100
 access-class 22 in
 access-class 24 out
 exec-timeout 20 0
 session-limit 7
 logging synchronous
 transport input ssh
webvpn gateway iti-ssl-vpn
 ip interface Dialer1 port 7443
 ssl trustpoint TP-self-signed-3420523579
 inservice
webvpn install svc flash:/webvpn/svc_1.pkg sequence 1
webvpn context iti-ssl-vpn
 ssl encryption rc4-md5
 ssl authenticate verify all
 policy group iti-ssl-vpn
   functions svc-required
   timeout idle 1800
   svc address-pool "vpn-client"
   svc default-domain "account-01.local"
   svc keep-client-installed
   svc dpd-interval client 30
   svc dpd-interval gateway 30
   svc rekey time 43200
   svc split include 10.1.0.0 255.255.0.0
   svc split include 192.168.0.0 255.255.0.0
   svc dns-server primary 10.1.1.19
   svc wins-server primary 10.1.1.19
 default-group-policy iti-ssl-vpn
 aaa authentication list vpn-client
 gateway iti-ssl-vpn
 inservice
end
I have CCSIP debug on but its not showing any debug when I am trying to call from out side to the main number and when you call shows line busy tone after a while any one can help please ?
regards
Ash
