FAX Configuration in CUCM
srinivascisco
I will have to configure FAX Machines(ATA) in my CUCM and SIP-PRI Gateways. let me know how do i start with? if there is a procedure or document please share.
Jitender Bhandari
Hi Srinivas,
See below for help.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/13949-fax-hairpin.html
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/115742-fax-modem-call-flows-00.html
https://supportforums.cisco.com/document/104086/commonly-supported-faxmodem-call-flows
(Rate if it helps)
JB
Thanks- Can you get me one sample end to end gateway configuration for ATA-187
