fax detect not working
iptsupport
Level 4
Level 4
Hello ,
I am experiencing an issue with fax-to-mail on my Cisco router. In the past, it was working fine, but recently, all fax detection has stopped working, and calls are disconnecting. I received the following error message: %CALL_CONTROL-6-APP_NOT_FOUND: Application faxdetect in dial-peer
any idea?
M02@rt37
Hello @iptsupport
On your dial-peer there is always the command "detect-fax" ?
Do you perform recently an upgrade of your Cisco Router ?
Best regards
1. Yes.
2.No
@iptsupport
Share output of that command
debug voip application
No others specific logs ?
Thanks.
Best regards
