Showing results forĀ
Search instead forĀ
Did you mean:Ā
Find if any number is call forwarding to another
hudsonp17
Is it possible to find out if a number is forwarding to specific DN without clicking on every number and checking if it is forwarded?
I have a user who is getting a lot of calls that are seem like they are being forwarded from one of our call in lines. The problem is we have dozens of these lines and it would take a great deal of time to check all of them; thus the question above.
Cisco Unified CM Administration
System version: 9.1.2.13900-10
Thank you
Phil
Jitender Bhandari
you can run the below query
run sql select dnorpattern,cfadestination,cfavoicemailenabled from  CallForwardDynamic c, numplan n where c.fknumplan = n.pkid and  (cfadestination != '' or cfavoicemailenabled ='t')
JB
